Brake Shoes Symmetrical
8 replies to this topic
#1 Homersimpson
Homersimpson
  • 840 posts
Posted 18 July 2018 - 08:27 PM
Hi All,
I've recently purchased some brake shoes for a sprite and they are very similar if not identical to a mini and the rear cylinders work in the same way.
The old shoes that I have removed and all the mini and other car shoes have the pad material set closer to one end of the shoe than the other, these units have arrived and are symmetrical, I've contacted the supplier who acknowledged this was wrong and sent me another set but they are the same.
I haven't driven the car yet but can anyone advise why shoes are normally like this and whether this will be a problem?
I've attached a picture with the two yellow arrows showing how it should be, mine has an equal gap at each side.
#2 nicklouse
  • 18,697 posts
Posted 18 July 2018 - 08:44 PM
so you have bought shoes for a what? a Mini Sprite or an Austin Sprite (rear wheel drive 2 seat sports car).
#3 Rorf
Rorf
  • 866 posts
Posted 19 July 2018 - 05:42 AM
Where the arrow is pointing is called the "leading edge" of the shoe and the drum should rotate towards the leading edge when the car is in forward motion. :D
#4 Spider
  • 15,141 posts
Posted 19 July 2018 - 09:24 AM
Sprite Shoes are the same (even by P/N) as Mini Ones.
As Rolf has said, they do have a leading and trailing edge and as can be seen here;-
#5 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 19 July 2018 - 12:04 PM
There are shoes out there that are symmetrical why they are like this I don’t know, what brand where they? I only supply unipart shoes with the correct edge
#6 Spider
  • 15,141 posts
Posted 19 July 2018 - 06:42 PM
I've been supplied loads of those. They are not right, just cheap junk.
#7 cian
cian
  • 869 posts
Posted 19 July 2018 - 06:50 PM
Possible savings with time to apply the braking material to the whole shoe instead of alternating
#8 Homersimpson
Homersimpson
  • 840 posts
Posted 19 July 2018 - 10:05 PM
Thanks guys, its an Austin Healey Sprite but I thought the shoes were the same as a mini, thanks for confirming.
As the supplier has sent two sets the same and reckons they are ok and they sold hundreds of sets last year with no complaints what do people think? To be honest i'm only putting the car on the road to drive to the Spridget 60th anniversary event which is a 30 mile round trip, then it will go back in the garage for another 4 years (or more).
I have only changed them as one was down to metal.
#9 Spider
  • 15,141 posts
Posted 20 July 2018 - 07:13 AM
I think you'd be very hard pressed to know any things is astray. Run with them.
