Churchill Third Motion Shaft Bearing Remover
12 replies to this topic
#1 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,042 posts
Posted 22 July 2018 - 08:40 AM
I'm stripping my gearbox and am wondering if anyone has the bearing remover as per the photo that they could get some dimensions from it so that I can make one? Outside Diameter, the counter bore diameter and depth, full width, slot size etc. Also a picture of it would be great.
#2 Spider
  • 15,136 posts
Posted 22 July 2018 - 09:47 AM
I did make one of those only about 2 or 3 years back, prior to that, nearly 30 years ago I made one from an old bearing;-
I'll also say that I find the Chuchill type quite clumsy to use by comparison, and although I now have one, I still gravitate back to old faithful.
#3 whistler
whistler
  • 1,818 posts
Posted 22 July 2018 - 10:10 AM
I think Minispares sell them.
#4 GraemeC
GraemeC
  • 7,440 posts
Posted 22 July 2018 - 10:43 AM
Guessworks sell them for £12
#5 alex-95
alex-95
  • 6,042 posts
Posted 22 July 2018 - 11:38 AM
ah right cheers, I'll see if I've got any bearings that will suit as it doesn't look like a double that you pull out.
Thanks, I did see them. I've got access to a lathe and mill so would rather make one.
#6 GraemeC
GraemeC
  • 7,440 posts
Posted 22 July 2018 - 07:30 PM
2.430” diameter,
1.004” slot width
0.495 thick at raised edge,
0.440” thick in centre
0.070” approximate width of flat section of raised edge
Rear side is flat
This actually the one for the 3 synchro box, but I’ve never had an issue using it on a 4 synchro.
I think the 4 synchro one has the centre raised again so as to push equally on the inner and outer races of the bearing.
Edited by GraemeC, 22 July 2018 - 07:40 PM.
#7 alex-95
alex-95
  • 6,042 posts
Posted 22 July 2018 - 07:49 PM
2.430” diameter,
1.004” slot width
Rear side is flat
Excellent, thank you very much.
#8 viz139
viz139
  • 682 posts
  • Local Club: Irish Mini Owners Club
Posted 23 July 2018 - 09:56 AM
I have the guessworks one and also there synchro ball bearing spring fitting tool, well worth it.
#9 dodge44
dodge44
  • 53 posts
Posted 23 July 2018 - 10:41 AM
Necessity is the mother of invention of course at 6.30pm on a Saturday evening - alternatively you can make the spacers from a sheet of hardboard cut out using hole cutters (2" and 1⅛") Might look like a bodge but works perfectly.
#10 alex-95
alex-95
  • 6,042 posts
Posted 26 July 2018 - 09:12 PM
Sorted.
#11 Bat
Bat
  • 903 posts
Posted 26 July 2018 - 10:33 PM
Hi,
Looks like an excellent bit of machining.
Cheers  :proud:
#12 GraemeC
GraemeC
  • 7,440 posts
Posted 27 July 2018 - 07:35 AM
Good work!
#13 alex-95
alex-95
  • 6,042 posts
Posted 27 July 2018 - 08:10 AM
Cheers Guys!
