Hello,
I’m installing a stage 2 on my 1275 cooper (with 1.5 rocker and electronic distributor).
Basically I don’t need any more depression so I’m thinking to replace the original (ugly) air filter box with another type of filter.
I see on internet is some K&N cones or ITG foam to be installed directly on the carburetor BUT this kind of installation are giving hot air to the engine. Which is less better than fresh air.
I was thinking of buying some inlet horn (not sure about the traduction) to be connected to a hose (Ø50) going to the front grille with a k&n filter at the end.
The inlet of the original air filter box is something like 20x60mm so Ø50 is bigger and more direct.
I think I can reduce the noise with this system also.
What are yout thoughts for that kind of system, did you already saw it mounted ?
