Baulk Rings Or Something Else?
5 replies to this topic
#1 Lennyliverpool
Lennyliverpool
  • 329 posts
  • Local Club: northampton
Posted 23 July 2018 - 12:09 PM
Ok am getting mixed messages here
Every once in a while my gearbox seems to show signs of baulk ring failure - crunching, difficulty getting from 3rd to 2nd etc etc
This happens for a couple of days - so I double declutch etc
Then all is fine for weeks/months on end - no issues with the box at all
I assumed - perhaps incorrectly? that if the baulk rings were shot would the gearbox always fail - or does it get worse only gradually??
Or is it something else?
Just trying to save money on taking it all out to possibly find nothing is wrong with the gearbox.....
Any suggestions gratefully received
Lenny
#2 Ethel
  • 26,037 posts
Posted 23 July 2018 - 12:37 PM
The baulk rings are a sort of friction clutch when they wear they just have less friction to speed/slow the gears to matching speed to engage. Double declutching is also a method to match gear speed, so if doing that properly can stop the crunching it may well just be the baulks and the gearbox can function well enough to last years.
Since it's a full strip down to replace baulks odds on it'll be worthwhile replacing other bits too.
#3 Bat
Bat
  • 903 posts
Hi,
Unless there's something really wired going on in your box I'd look at clutch hydraulics first.
What oil are you using, although I'd expect that to be an all the time problem as well?
Cheers  :proud:
#4 Bat
Bat
  • 903 posts
Posted 23 July 2018 - 12:39 PM
Hi,
It is a wear thing with baulk rings, but that wouldn't explain it being fine for weeks at a time..
Cheers  :proud:
#5 Lennyliverpool
Lennyliverpool
  • 329 posts
Posted 23 July 2018 - 03:17 PM
That's what I thought seems to long between issues to perhaps be the Baulk rings - if clutch what do you suspect?
Just seems so random and spaced out between issues?
Perhaps Guessworks could offer a suggestion?
Lenny
#6 Spider
  • 15,063 posts
Posted 23 July 2018 - 06:23 PM
Hi,
Cheers  :proud:
This or the Primary Gear Bushes are were I'd be looking.
With the Baulk Rings, it's a one way trip, ie, they won't get bad and then come good for a while.
