Rolling Road Suggestions Wanted
15 replies to this topic
#1 beardylondon
beardylondon
  • 1,725 posts
Posted 24 July 2018 - 08:54 AM
Just got the new engine in, which I will report back on in the original thread soon.
I need to get it set up on a Rolling Road, does anyone have any suggestions of a good company with Rolling Road facilities in West/South West London, or Hampshire / Surrey / Berks area?
Thanks.
#2 mab01uk
mab01uk
  • 12,925 posts
Posted 24 July 2018 - 11:33 AM
Some suggestions here:-
http://www.theminifo...-in-south-east/
#3 beardylondon
beardylondon
  • 1,725 posts
Posted 24 July 2018 - 06:25 PM
Thank you very much.  Someone suggested I run the engine in for 1000 miles before tuning, is this right?
#4 imack
imack
  • 2,372 posts
Posted 25 July 2018 - 04:28 AM
Peter Baldwin, now at regency autos Cambridge, he set up my car a couple of years ago, fantastic.
#5 Dusky
Dusky
  • 5,322 posts
Posted 25 July 2018 - 05:54 AM
Not really. If its running way lean or rich you ll damage the engine. Best thing is to tune it 2 times, once on the initial start, and then after its ran in.
#6 happydude2012
happydude2012
  • 332 posts
Posted 25 July 2018 - 07:42 AM
yes my local rolling road suggest that - dont know about others but i think its to do with allowing everything to bed in.
As long as the timing is right the rolling road can wait a while.
Also remember to re-torque the head after 500miles or so, i didnt and ended up with **** flying everywhere and leaks/.
#7 Minigman
Minigman
  • 803 posts
Posted 25 July 2018 - 11:57 AM
I can’t help with a RR unless you fancy going to Slarks (about 80 miles from you) who I use. But I would suggest getting the RR booked ASAP. If the engine has not been set up properly already it may well be damaged before it’s run in. I speak from experience sadly.
#8 imack
imack
  • 2,372 posts
Posted 25 July 2018 - 01:24 PM
As above, I've destroyed an engine due to it running too lean, an expensive lesson learnt.
#9 beardylondon
beardylondon
  • 1,725 posts
Posted 30 July 2018 - 02:38 PM
Thanks for all the replies.
So it is running too lean, it probably needs a new needle, I’m toying with the either popping a new needle in and running it in or just taking it straight to Slark’s before running in.
I’ve been reading up on needles and I currently have BBP needle and I clearly need one that will make it richer, so perhaps a BDL.
Anyway here is the spec, what does everyone think?
1293cc
New larger 35.6mm inlet valves
New exhaust valves - size not changed
Fully balanced
Newman Cams 270 billet cam
10.5:1 compression
HIF44 1” 3/4 Carb
Minispares Alloy inlet (not heated)
Maniflow LCB
Playmini Stainless exhaust
Electronic ignition
Standard Air filter
#10 racingbob
racingbob
  • 3,061 posts
Posted 30 July 2018 - 03:05 PM
1293cc
Fully balanced
10.5:1 compression
HIF44 1” 3/4 Carb
Maniflow LCB
Electronic ignition
Standard Air filter
bdl wi'll help or a bpd or bce similar spec to mine
#11 maccers
maccers
  • 1,880 posts
  • Local Club: LSMOC
Posted 30 July 2018 - 03:45 PM
Stuart at VMAX near Hampton Court has a RR I've been to a few times.
#12 beardylondon
beardylondon
  • 1,725 posts
Posted 30 July 2018 - 04:02 PM
thanks for the needle suggestions, BPD doesn’t come up on SU’s website?
#13 beardylondon
beardylondon
  • 1,725 posts
Posted 30 July 2018 - 06:10 PM
Thanks very much
#14 beardylondon
beardylondon
  • 1,725 posts
Posted 31 July 2018 - 04:09 PM
http://www.retromini...products_id=673
according to that the BCE needle suits my cam!
#15 beardylondon
beardylondon
  • 1,725 posts
Posted 02 August 2018 - 03:26 PM
Stuart at VMAX thinks BCE may be too to rich for my set up, so have ordered a BDL, will see how it goes. I will take it there for tuning soon.
Question about the air box, I am running the metal version of the below airbox, and I had been running without the extra pipe circled in red, what is best, to leave that pipe on or off?
Edited by beardylondon, 02 August 2018 - 03:27 PM.
