Wheel Stud Pcd's
2 replies to this topic
#1 elf66
elf66
  • 55 posts
Posted 25 July 2018 - 08:36 AM
Hi,
Are the wheel stud/bolt PCD sizes the same across all mini wheels?
I have a trailer with 10" mini wheels that when loaded run rather hot, so i was considering fitting the larger 12" or 13" wheels with the correct load rated tires. Unfortunately i cant find PCD info for the larger rims.
Are they all 4" PCD or did it change with the larger size rims?
many thanks
#2 nicklouse
  • 18,724 posts
Posted 25 July 2018 - 08:39 AM
All 4x4"
#3 Spider
  • 15,201 posts
Posted 25 July 2018 - 06:32 PM
The later Minis had 12" wheels and Aust Mokes had 13" wheels, all on the same stud pattern and these should be fairly easy to find, even in the UK.
The Morris Minor also used 4" PCD and had 14" wheels if that's any help.
