horn gone
bankxi
, Aug 05 2004 01:23 AM
10 replies to this topic
Posted 05 August 2004 - 01:23 AM
one day i was beepin my horn for my mum 2 hurry up and it went beep 2 times and then it went dead as a result of this i had to shout my mum and this gave me a bad throught so now i need to fix my horn any ideas what could be the prob
Posted 05 August 2004 - 06:43 AM
hi bankxi
first check the fuses
then the connections on the horn, not forgetting the earth
if they are all good you need to test the horn
you need a piece of wire with a clip on it, clip it onto on of the power fuses on the fuse box, and then touch the other end onto the power for the horn (you may need your ign on depending on which fuse you have the lead connected to ( the 2nd from the top is live?)(so you won't need ign on).
if the horn works then you need to check if the switch is working, and your getting power to it.
you will need a voltage tester for this
hope this helps.
(any other problems can you post them in technical and problems)
hope this helps.
Posted 05 August 2004 - 08:09 AM
thanks for the help ill look at the horn soon thanks again and i will put it in technical and problems next time
bankxi
bankxi
Posted 05 August 2004 - 09:06 AM
Hmmm that sounds familiar,
My horn stopped working a while ago, traced it back to the stalk, so I'll be needing a new one.
I cant beep people when they cut me up
just have to shout at them!
Posted 05 August 2004 - 09:07 AM
lol move out the way a** h**e lol well when u get 1 can u tell me how much it cost thanks
bankxi
bankxi
Posted 05 August 2004 - 09:59 AM
ulternativly get a wooden stik with a lump of metal on the end (i think they are called hammers not to sure) and some WD40 :tongue: get ure missus to keep pressing it and spray the WD40 at the horn and keep hitting! after 5 or 6 times have a loook at the fuses etc (only hit the horn!)
:grin:
Posted 05 August 2004 - 10:03 AM
thanks for all the help from you people
bankxi
bankxi
Posted 05 August 2004 - 08:32 PM
Not the best Idea to spray WD into your horn I'm afraid. Same reason as you don't want it anywhere near your ignition switch. Risk of fire. Horns use a lot of current and are basically a set of points. They are capable of producing nice fat sparks from time to time.
Posted 05 August 2004 - 09:49 PM
a ggod point was made there by dan wd40 is a penetrating oil used to free off stubbern nuts, bolts, studs and anything else that doesn't want to move, IT IS NOT FOR ANYTHING ELECTRICAL.
for that you need to get a special electrical conductor spray, i have used it in the past with work but cant remember its name at the moment. just don't use wd40
Posted 05 August 2004 - 09:51 PM
ok didnt think i would up wd40 arout there any way thanks for the help
