Roof Corners/gutter Repair
7 replies to this topic
#1 blacktulip
blacktulip
  • 6,224 posts
Posted 28 July 2018 - 09:23 PM
Hi, What's the best course of action to restore this area?
#2 Daz1968
Daz1968
  • 2,058 posts
Posted 28 July 2018 - 10:10 PM
I cut out the section completely, then fabricated repairs to each panel separately, worked out really well for my first attempt.
But on the windscreen surround I just purchased the full panel, wasn’t a lot more than a heritage scuttle for the peace of mind knowing everything had been replaced. It also comes with inner pillar panels.
This stage I had fitted a piece on upper frame, and cut out the rest
42879783142_28bb002419_z.jpg1B8018AE-68C9-47D6-BD2E-04BDDDB18499 by darren carr, on Flickr
42210221984_c23734e142_z.jpg9E1BB872-9E6D-48FF-9870-1F175191CA20 by darren carr, on Flickr
Then I repaired the roof and gutter
42027031425_82228bcdcb_z.jpgA043A1B4-9F16-4CFE-9EBA-38BE9DCC094B by darren carr, on Flickr
Then fitted new windscreen surround, just took my time and used templates and also blocks to help shape the material
42027030795_ba4d5eeb05_z.jpgCECBA862-6979-47E9-9B2F-EC2C47D363B1 by darren carr, on Flickr
#3 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 29 July 2018 - 07:34 AM
or get a roof corner from a scrap car and use what you need i still have some
#4 Ethel
  • 26,022 posts
Posted 29 July 2018 - 09:02 AM
You might manage to scrub it up and soak it in rust eater/converter, but if the rust is inside the seam it's liable to resurface.
If you make your own patches do it before you cut out the old and you can shape then over the top.
Using copper (scrap pipe) to back your welds will help you bridge gaps and be tidier, especially where it'd be hard to get a grinder on 'em.
If the roof itself isn't penetrated to the inside, I think I'd cut out the back and side panel rot to expose the roof part of the seam treat that and patch back up - better than adding a join above the gutter to leak and there's less shaping and better opportunity to hide joins below.
#5 SamG
SamG
  • 88 posts
Posted 21 August 2018 - 09:24 AM
Fantastic work there! Im having to do the exact same repair on mine this week.
I also need to fit a windscreen surround panel, do you have any more pictures or a build thread detailing the process you used?
Sam
#6 Daz1968
Daz1968
  • 2,058 posts
Posted 21 August 2018 - 12:10 PM
Thanks,
not sure if much more on my post, but the repairs start on this page
http://www.theminifo...-cooper/page-16
its pretty straightforward if you take your time and make templates if needed, I used a bent piece of 8mm bar shaped to roof corner to shape the corner piece and a block of wood cut to correct radius for the top corner of frame
Edited by Daz1968, 21 August 2018 - 12:11 PM.
#7 harrythehat
harrythehat
  • 275 posts
Posted 21 August 2018 - 01:34 PM
Nice piece of work
#8 blacktulip
blacktulip
  • 6,224 posts
Posted 22 August 2018 - 09:18 AM
Nice work, thanks for the advice.
