How Do I Measure Lobe Lift On A+ 1275
8 replies to this topic
#1 happydude2012
happydude2012
  • 332 posts
Posted 03 August 2018 - 09:48 PM
Ok chaps
AC asked i measure lobe lift on my engine to determine if my cams had it.
Presumably i can do this with the engine in?
How?
ha ha
sorry lads ive never done this and id like to learn - anyone got a video or diagram?
thanks
#2 Cooperman
  • 23,366 posts
Posted 03 August 2018 - 10:45 PM
You need a Dial Test Indicator (DTI) with a magnetic base.
Use the DTI to measure the movement of the rocker on the push-rod side of each rocker from lowest point to highest point. That is the lobe lift, but the actual valve clearance must be added to this figure, so it must be measured with a feeler gauge or, alternatively, the valve clearance re-set to zero before doing the measuring.
#3 GraemeC
GraemeC
  • 7,451 posts
Posted 04 August 2018 - 07:03 AM
Why add valve clearance to that measurement - is lobe lift not irrespective of clearance?
I can see the value in setting to zero, just to ensure everything on the cam side of the rockers stays in contact and there chance of float to give poor readings.
#4 happydude2012
happydude2012
  • 332 posts
Posted 04 August 2018 - 07:42 AM
ok - ive bought one of the magnetic based DTIs and damn it im going to learn this.
So cooperman, i can do this with the rockers on? VERY COOL!  i assumed that id have to remove them and use the pushrods or something.
Im also after buying a compression tester - which ill be asking loads of questions about.
#5 Cooperman
  • 23,366 posts
Posted 04 August 2018 - 09:31 AM
If the rocker is physically held onto the push rod end, then there is no need to consider the valve clearance, but there is a chance that the initial valve clearance will be under the push rod tip, not at the valve stem top.
The best way is simply to remove the valve clearance. That is what I always do as it removes any chance of error. Alternatively the rocker can be physically held down onto the push rod top during the initial setting of the DTI to zero.
In fact, if the rocker is on the valve stem, the amount to be deducted is the valve clearance divided by the rocker ratio.
Just removing the possibility of error caused by the valve to rocker clearance is important.
#6 happydude2012
happydude2012
  • 332 posts
Posted 04 August 2018 - 04:57 PM
do i do this on every rocker to check lift on each one?
or just the end one?
#7 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 04 August 2018 - 05:40 PM
I would check each one, you can then tell if one or more is worn
#8 happydude2012
happydude2012
  • 332 posts
Posted 04 August 2018 - 06:50 PM
got it! thanks chaps
the more i look at the symptoms, the more it sounds like a worn cam lobe.
Rocker tapping on a cold engine gradually fading when the oil dampens it -  , the odd backfire/crack at high revs in neutral.
I think im dooooomed lads.
nice generic but useful article here on symptoms if anyones interested.
https://itstillruns....ft-6293277.html
#9 Cooperman
  • 23,366 posts
Posted 04 August 2018 - 06:51 PM
If checking for lobe wear, then each one needs to be checked.
