Fitting A Tow Bar To A Mini
9 replies to this topic
#1 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 05 August 2018 - 06:53 AM
Hi all I was wondering if anyone had an photos of the underneath and back of the mini of where this is fitting I have a good Idea of where it all needs to bolt up to.
Just want to some pics to double check.
Thanks guys and girls..
#2 Bat
Bat
  • 903 posts
Posted 05 August 2018 - 07:05 AM
Hi,
Just check you can fit a towbar first.
I read in the MPI manual that "this car is not suitable for towing" don't know if it applies to SPI too?
Cheers  :proud:
#3 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 05 August 2018 - 07:52 AM
It depends what tow bar design as there are a few.
I've seen some that bolt to the rear bumper lip, but I personally wouldn't want it fitted on there. The last two tow bars I have had on minis I made sure they were the ones that have the spreader plate that bolts to the rear part of the subframe and then a single bolt through the rear seat bench.
Same sort as in the link - https://www.minispor...ng-bar-kit.html
I never got a picture of mine from underneath, but I might have just a normal rear end pic of the mini with it fitted and can get one of the mounting holes to give you an idea
#4 minimissions
minimissions
  • 3,427 posts
Posted 05 August 2018 - 08:54 AM
Thanks yes she can tow I checked all that.... :D
I have seen that kit from mini sport but wont be paying their prices.
I have seen the same on the bumper lip it doesn't sound the best place to fit it. The bar I am looking at is very much like the mini sport kit (and like the one you have mentioned) there is a row of bolts through the subframe on the valance end, then looks like a few go through the floor on the boot end.
Just wanted pics of someone who has done this, as I was thinking it would need a strengthener spreader plate to make this nice and strong...
Any photos would be very helpful
thanks
#5 Homersimpson
Homersimpson
  • 831 posts
Posted 05 August 2018 - 10:51 AM
Looks a good kit but I wonder how it works with part of it being on the subframe and part fixed to the body when the subframe is rubber mounted?  I wonder if it increases the noise/vibration/harshness at all? Alternatively is their a risk of continually stressing the fixing to the rear seat eventually leading to fatigue fracture?
Edited by Homersimpson, 05 August 2018 - 10:57 AM.
#6 nicklouse
  • 18,657 posts
Posted 05 August 2018 - 12:06 PM
reading this a few points. the rover Minis have no approval to tow. but can have a tow bar fitted for a bike rack etc. Any tow bar fitted must have approval. gone are the days of making your own.
there are a few towbars out there that do have local approval. but that does not make it OK to use somewhere else.
#7 absx2
absx2
  • 918 posts
Posted 05 August 2018 - 12:10 PM
I had a towbar on a 1989 mini. I fabricated it myself and it bolted directly to the subframe in four places so no need to drill holes in the bodywork.
That was a while ago and before the law changed but it was a beauty, so over engineered you would have to rip the entire rear subframe for it to fail.
#8 minimissions
minimissions
  • 3,427 posts
Posted 05 August 2018 - 12:49 PM
I believe there is a cut off date for a mini being able to tow, basically 96-97 I am sure I have read this in a number places...
#9 nicklouse
  • 18,657 posts
Posted 05 August 2018 - 01:12 PM
it is not the date it is the Maker ie Rover. but any fitted to any Mini needs to have the approval tag on it.
#10 nicklouse
  • 18,657 posts
Posted 05 August 2018 - 01:24 PM
the date you are thinking about may be the date that required all towbars to have the E mark.
Tow bars
All tow bars fitted to cars registered after July 1998 must have an E approved tow bar fitted. Rover Mini is not E approved so no tow bar can be fitted to minis registered on and after 1st August 1998 .So if a mini was registered on 31 July 1998 it can pull a trailer however if the same car was registered on 1 August 1998 it cannot. However a towbar can be fitted with electrics to a S reg onwards car if it is used for cycle carriers etc .
