Oil Dipsticks And Tubes
14 replies to this topic
#1 MiniBGT
MiniBGT
  • 96 posts
Posted 23 August 2018 - 01:34 PM
I have a 1275 pre-A+ block and the 12A1261 dipstick from a 998 block.  I have tried a 12G107 plastic dipstick tube but each time I pull the dipstick out the tube comes out of the block.  Has anyone encountered this before, if so what was the solution?  I understand that I should have a metal tube but these are no longer available.
#2 nicklouse
  • 18,696 posts
Posted 23 August 2018 - 01:41 PM
Not much you can do other than hold the tube.
#3 Itsaminithing
Itsaminithing
  • 853 posts
  • Local Club: Not One Worth Mentioning
Posted 23 August 2018 - 03:45 PM
The pre A+ metal tubes are not NLA -but they aren't cheap.
http://www.retromini...products_id=665
or if you want to risk second hand
https://www.ebay.co....w4AAOSwxNxba2~8
#4 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 23 August 2018 - 04:01 PM
Would a rubber washer/seal around the section that fits into the block help? Might just be enough to grip ...
#5 MiniBGT
MiniBGT
  • 96 posts
Posted 23 August 2018 - 04:04 PM
Many thanks Itsaminithing I have just purchased it.  Thought that it is worth a punt.
#6 Itsaminithing
Itsaminithing
  • 853 posts
Posted 23 August 2018 - 07:35 PM
I presume they were originally fitted with a high temp retaining compound or something similar.
If no-one comes up with an answer it might be worth starting a new thread asking what (if anything) would be the best thing to use (esp as you're tight & went for a second hand one :P).
#7 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 23 August 2018 - 07:56 PM
Just push fit ....
#8 nicklouse
  • 18,696 posts
Posted 23 August 2018 - 09:15 PM
just push fit.
#9 blacktulip
blacktulip
  • 6,224 posts
Posted 23 August 2018 - 10:22 PM
I bought a metal one from minimine last year
#10 russo
russo
  • 191 posts
  • Local Club: Minis In Nelson Inc.
Posted 24 August 2018 - 02:37 AM
Knurl the end of the dipstick tube and locktight it.
#11 Spider
  • 15,136 posts
Posted 24 August 2018 - 03:26 AM
For the short while I used the Plastic Tubes, I used adhesive to hold them in, but really, they are junk. I've always noticed on cars fitted with them, even the original factory ones, there's always at least a stain of oil around them, or more.
I know the metal ones are dear, but they are the only ones worth fitting, the longer ones are better.
#12 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 24 August 2018 - 11:59 AM
The metal ones are NLA
Unless MSprt auz have some, I supplied them a couple of batches
I am trying to get the metal ones remade, but don't hold your breath
#13 Itsaminithing
Itsaminithing
  • 853 posts
Posted 24 August 2018 - 02:20 PM
Did you supply your 12A1261 tubes to P&L Minis? - they're still showing stock.
#14 Spider
  • 15,136 posts
Posted 24 August 2018 - 06:59 PM
I don't think Mini Sport (in Aust) have any left.
They are not something that normally wears out, have a look for used ones, I've managed to pick up a few.
I have made them when desperate, but not my first choice !!!!
#15 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 24 August 2018 - 09:04 PM
  No...they must be the last few
