I have a 93 sprite that I have been rebuilding the engine on. I have come to put it back together and noticed there is no flare on the end of the oil filter pipe and was wondering how on earth this seals and the pipe can literally be pulled out of the block when the nut is tightened. Has a flared end fallen off of the end of something?
Regards
Remy
Oil Filter Pipe Help
Remy
, Aug 24 2018 01:45 PM
4 replies to this topic
Posted 24 August 2018 - 01:45 PM
Posted 24 August 2018 - 02:00 PM
Posted 24 August 2018 - 02:02 PM
they should have a olive on the end but no flare, however they can pop out of the engine and dump your oil.
It was a money saving thing by rover apparently.
I swapped my 93 sprites to this for piece of mind
http://minispares.co...|Back to search
Edited by bae1994, 24 August 2018 - 02:03 PM.
Posted 24 August 2018 - 02:16 PM
If you clean it very, very carefully to remove all oil, and then run emery tape round the pipe and through the olive, the olive back can be soldered back on.
Posted 24 August 2018 - 02:26 PM
Thanks guys
