Roof Gutter Trim Clips
5 replies to this topic
#1 mgjalopy
mgjalopy
  • 50 posts
Posted 25 August 2018 - 08:21 AM
Hi All
A silly question but how do the clips fit onto the roof gutter trim of a classic mini? I have tried both ways round and neither seems to hold the trim in place. It currently only has one at the back but I need to add one at the front and at each side as the trim is loose. Is there some special knack to fitting them?!
#2 Bat
Bat
  • 903 posts
Posted 25 August 2018 - 08:34 AM
Hi,
The clip is just to cover the joins like the ones in the front and rear screens.
I there should only be one at the front and another one at the rear.
Cheers  :proud:
#3 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 25 August 2018 - 08:59 AM
I'm sure there's only one, personally leave the trim off
#4 harrythehat
harrythehat
  • 275 posts
Posted 25 August 2018 - 12:39 PM
if there original they fit patent parts are a bit dubious
got some from minimine they were sweet as a nut
#5 mgjalopy
mgjalopy
  • 50 posts
Posted 04 September 2018 - 01:25 PM
Thanks for your replies guys. My reason for wanting to put additional clips at sides and front was to stop the trim coming off every time I remove the car cover. If they are only intended as joining pieces then I guess I will have to come up with some other way of stopping it from moving! I don't want to remove it as I think it enhances the look of a mini. Gorilla Glue maybe!?
#6 luismx123
luismx123
  • 525 posts
Posted 05 September 2018 - 06:08 AM
As Cal said, I'd remove it too. Had it on mine, and got annoyed by it yellowing in the sun and flattering on the highway as I couldn't get it to fit tightly. Plus it his some rust that needs to get worked on soon.... :/
I'd say use some silicon or a removable type of glue, incase you one day, decide to remove it and to keep water out from under there as its prime location to get caught up ...
