Crackle Finish Rocker
8 replies to this topic
#1 Charliehelms
Charliehelms
  • 13 posts
Posted 28 August 2018 - 07:55 PM
Hello all
Does anyone know where I can get a crackle black finished rocker cover? I cant seem to find one easily
#2 nicklouse
  • 18,697 posts
Posted 28 August 2018 - 08:02 PM
most people do them themselves with crackle finish paint it aint hard.
#3 johnR
johnR
  • 2,302 posts
Posted 28 August 2018 - 08:24 PM
Warm the cover before you put the first coat of paint on and be prepared to use the hot air gun on areas that don't initially crackle
#4 Aaron3
Aaron3
  • 331 posts
  • Local Club: Sunmc
It’s straight forward to get a crackle effect. Apply a base coat of oil based paint and allow to dry, apply a layer of pva glue (thick layer for big cracks, thin watery layer for small cracks) allow glue to go tacky to the touch (not completely dry) then add your layer of top coat and watch the cracks appear. You can experiment with different colours of base and top coats. When it’s dry add a coat of clear lacquer.
#5 Cooperman
  • 23,326 posts
You get that without trying if you use cellulose paint on top of synthetic  ;D .
#6 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,042 posts
Posted 28 August 2018 - 08:31 PM
Depends on the style of cover you want. As said can be done yourself. I would recommend VHT wrinkle paint, I've got great result's from it.
Edited by alex-95, 28 August 2018 - 08:33 PM.
#7 timmy850
timmy850
  • 3,388 posts
  • Local Club: MITG
Posted 28 August 2018 - 10:10 PM
Yep, VHT Wrinkle Plus. There is a guide here: http://build-threads...-texture-paint/ or you can also ask your local powdercoaters if they can offer a crackle finish
#8 Charliehelms
Charliehelms
  • 13 posts
Posted 30 August 2018 - 07:14 PM
Thanks for the help everyone
#9 sansamn
sansamn
  • Just Joined
  • 47 posts
Posted 04 September 2018 - 12:04 PM
I bought a couple of crinkle finish rocker covers from Nick at Min-e-Bitz.
http://www.min-e-bitz.co.uk/
Attached File  Mini Engine Bay.jpg   88.81K   5 downloads
