Undersize Big-End Bearings
9 replies to this topic
#1 DeadSquare
DeadSquare
  • 3,195 posts
Posted 29 August 2018 - 06:31 PM
Does anyone know of any .080" undersize 848 / 997 / 998 / 1098 or Cooper S big-end bearings for sale anywhere?
#2 gazza82
gazza82
  • 3,020 posts
  • Local Club: TMF+
Posted 29 August 2018 - 07:00 PM
Biggest I've seen is +60 ...
Contact FW Thortons in Macclesfield and they will tell you if they exist ... or you need a new crank ...
Edited by gazza82, 29 August 2018 - 07:02 PM.
#3 DeadSquare
DeadSquare
  • 3,195 posts
Posted 29 August 2018 - 07:03 PM
Thank you.
#4 Cooperman
  • 23,327 posts
Posted 29 August 2018 - 09:30 PM
F.W. Thornton in Shrewsbury would be closer for you I think.
I have never seen an 80 thou undersize journal bearing. On a Cooper 'S' it would have ground through the nitriding and an 850 crank would be getting very weak at that size.
#5 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 29 August 2018 - 09:37 PM
Never seen an -0.080" under.
Ac
#6 Spider
  • 15,160 posts
Posted 30 August 2018 - 06:17 AM
I've not seen a -0.080" either, but you can make some or get them made, not hard really, though at that size bearing, you'd most like want to use laminated materials or a thick backing shell, before laying down the babit material.
#7 DeadSquare
DeadSquare
  • 3,195 posts
Posted 30 August 2018 - 08:55 AM
Thanks to all for your comments;  it was a long shot.
I'll do what I did last time, sweat a strip of brass shim on the back of the bearing, and file to fit.
#8 gazza82
gazza82
  • 3,020 posts
  • Local Club: TMF+
Posted 30 August 2018 - 09:24 AM
Surely the shape of the bearing shell is going to be wrong? .. it will be too wide at the ends. I know 20thou isn't much ... I guess it may squeeze up .. or wear quicker!
#9 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 30 August 2018 - 12:12 PM
Th shells circumference will be too big if you do that. You need to reduce that to achieve the correct crush.
Ac
#10 DeadSquare
DeadSquare
  • 3,195 posts
Posted 30 August 2018 - 04:53 PM
Ac
"I file it to fit"
Actually, I'll scribe it, touch it on the grindstone and finish it on a file.
