When i rebuilt my mg metro engine i had the 65m electronic distributor re curved by Ac Dodd and refitted it in the same position as i had on my previous 998 build with the drive slot at the 8 to 2 o'clock position, i had the car rolling roaded and was told that the cam timing was way out,( AC had given me the figure to time the cam in at and I trust the information that he gave me} now i had been pretty meticulus when setting the cam timing and was very dissapointed with the result although i was sure i had correctly set the timing. At the weekend i picked up a copy of the metro Haynes manual as it has the MG supplement which covers the engine and ignition settings for the engine that i have fitted, now i have found a section and diagram which explains that when fitting the 65m distributor that the drive should be fitted with the slot fitted further round in a clockwise direction, i have now done this and would like to know if this was the cause of the cam timing seeming to be incorrect?
All of this has been very frustrating as i was pleased with the performance of the home built engine but the rolling road operator has really put a downer on what i thought i'd done well.
