3 Clock Dash Installation
5 replies to this topic
#1 luismx123
luismx123
  • 525 posts
Posted 04 September 2018 - 06:43 AM
Hey all,
So I want to swap out my current dashboard (see fotos below) to a classic 3-gauge style setup with an extra Tachometer and a Smiths car clock. In total the new setup will comprise of: Clock, Tachometer, Temperature, Speedo and Oil pressure.
The 3 clock center console is arriving in the next few days and the rest wil have to be purchased.
Whilst Im at it I thought Id ask what cables, sensors etc I will need to make the install work, or if its just a "plug and play" situation - meaning the Smiths clocks use the same cables, sensors, etc.
The 3-clock Im getting has - according to the photos - most of its cables still connected, just cut short.
If anyone has done this and is willing to send me a list of parts I need/have a chat and help me out Id be very thankful.
My brain says link the blue cable to the blue cable, and the green to the green - thats about as far as I can think!
thanks a ton
Luis
p.s How to do I set the odometer to my current km standing? The Speedo I am getting has 49000km, whereas my mini is sitting at 69000. Is there a simple way to turn the numbers? Ive heard of people using drills to spin the odometer
Edited by luismx123, 04 September 2018 - 09:28 AM.
#2 nicklouse
  • 18,598 posts
Posted 04 September 2018 - 07:53 AM
so you are change in to or from a center console? you are as clear as mud.
you don't change the odometer you just make a not of the old and the new. (talk to you local test agency/register about what is needed in your area)
#3 nicklouse
  • 18,598 posts
Posted 04 September 2018 - 07:58 AM
http://www.theminifo...ter +speedo +to
 may help
#4 luismx123
luismx123
  • 525 posts
Posted 04 September 2018 - 09:22 AM
Woops. I did say Im switching TO a classic 3 gauge. Changing to a center console, but will be adding 2 more clocks.
thankkkkks
#5 unburntfuelinthemorning
  • 1,983 posts
Posted 04 September 2018 - 11:05 AM
If you use a drill where the speedo cable fits and run it at a speed that makes the speedo read 100 km/hr for 200 hours non stop you will do 20,000 km and make up the difference.
#6 luismx123
luismx123
  • 525 posts
Posted 04 September 2018 - 11:18 AM
R.i.p my drill :D
