Main Cap Dowel
7 replies to this topic
#1 Mini_Problems_
Mini_Problems_
    Formally known as Cmontgomeryc
  • Just Joined
  • 46 posts
Posted 04 September 2018 - 04:49 PM
So my block has just come back from the machine shop but the dowels were removed for the maching. Can they be simply tapped in or pressed in?I dont want to ruin the alignment of the main caps obviously! cheers in advance
#2 Swift_General
Swift_General
  • 871 posts
Posted 04 September 2018 - 04:56 PM
Yep. They shouldn't need to be pressed though. Just tapped down square so they're home.
#3 Mini_Problems_
Mini_Problems_
  • Just Joined
  • 46 posts
Posted 04 September 2018 - 05:12 PM
Thankyou for your reply, is there anything i can use to tap it in, i imagine there is a special collard punch out there
#4 mini13
mini13
  • 3,811 posts
Posted 04 September 2018 - 05:14 PM
Check them over for any obvious marks from removal, they should go in with a bit of resistance, if they are loose or need more than a tap with the hammer handle ( it's wood or rubber so won't damage them) bin them and get a billet set from swiftune for 15 quid.
It's important they are right, as if they are loose the alignment can be off causing binding.
#5 Mini_Problems_
Mini_Problems_
  • Just Joined
  • 46 posts
Posted 04 September 2018 - 05:23 PM
Brilliant i will take your advice as a tap was used to remove the dowels
#6 Mini_Problems_
Mini_Problems_
  • Just Joined
  • 46 posts
Posted 04 September 2018 - 05:25 PM
https://swiftune.com...p-dowels-2.html Why does it say 1300?
#7 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 04 September 2018 - 05:31 PM
A lot of adverts have said 1300 in the past. 1300GT was only a 1275.
#8 mini13
mini13
  • 3,811 posts
Posted 04 September 2018 - 06:51 PM
Yep 1275 and 1300 is the same thing,
to be honest a tap is a pretty good way if heating the dowels, the main issue is when someone goes at em with pliers or molegrips!
