Acceleration After Max Bhp
17 replies to this topic
#1 Minigman
Minigman
  • 779 posts
Posted 04 September 2018 - 05:50 PM
Will a car stop accelerating once max bhp has been achieved?
#2 Steve220
Steve220
  • 5,068 posts
  • Local Club: BMC
Posted 04 September 2018 - 06:01 PM
No, max BHP is just that, it's maximum. As long as you have the torque to overcome friction (both mechanical and wind drag), the car will continue to accelerate until it comes to its vmax where power is equal to drag.
#3 Minigman
Minigman
  • 779 posts
Posted 04 September 2018 - 06:12 PM
I wonder how VMax is calculated on a mini. Probably well beyond my A-level maths of yesteryear.
I know the project 64 car made low 300bhp to achieve 146mph. How much bhp would be required to make 120mph?
#4 DeadSquare
DeadSquare
  • 3,197 posts
Posted 04 September 2018 - 06:23 PM
That depends on the gradient and wind direction.
#5 Steve220
Steve220
  • 5,068 posts
  • Local Club: BMC
Posted 04 September 2018 - 06:31 PM
There are so many factors! Torque, BHP, wheel size, rolling resistance coefficient, weight, chassis drag coefficient, gear ratios, final drive ratio, mechanical drag factors.
#6 smurfomatic
smurfomatic
  • 461 posts
Posted 04 September 2018 - 06:36 PM
Using a formula found online here: https://metinmediama...bugatti-veyron/ (this site has examples of a Mercedes C180 and Bugatti Veyron)
Power (in Watts) = 1/2 * coefficient of drag * air density * frontal area (m^2) * velocity (metres per second)^3
Air density is 1.25 at sea level, and according to this thread http://www.theminifo...icient-of-drag/ coefficient of drag is 0.48 to 0.53, frontal area is 1.533 m^2. 120mph = 53.65 m/s.
Therefore, power = 1/2 * 0.5 * 1.25 * 1.533 * 53.65^3 = 73.98kW = 99.2HP.
Would a 100BHP Mini make 120mph?
#7 nicklouse
  • 18,705 posts
Posted 04 September 2018 - 06:40 PM
your gear ratios will also effect things mine will only just go over 100mph with current set up.
#8 Minigman
Minigman
  • 779 posts
Posted 04 September 2018 - 07:43 PM
1293 Miglias with 140bhp do 125mph on a 3.9fd at 8000rpm.
Just wondering how much faster they’d go on 2.76.
‘Some’ say they’d go much faster but I’m not convinced.
I think you need a lot more power to get above that.
Edited by Minigman, 04 September 2018 - 07:46 PM.
#9 nicklouse
  • 18,705 posts
Posted 04 September 2018 - 07:57 PM
they dont go that fast at 8k 3.9 more like 115mph
#10 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 04 September 2018 - 09:07 PM
Nor do they have 140hp.
Phil.
#11 Minigman
Minigman
  • 779 posts
Posted 05 September 2018 - 07:22 AM
I wonder why mini7 publish this info?
#12 dotmatrix
dotmatrix
  • 441 posts
Posted 05 September 2018 - 07:49 AM
my k-series metro with 106bhp did 120mhp so providing the various drags is comparable the answer is yes almost.
#13 dotmatrix
dotmatrix
  • 441 posts
Posted 05 September 2018 - 07:51 AM
Phil.
from the same dyno I use with my cars I have seen outputs from other cars of 135 and 137 bhp on a 1293 5-port swiftune engine, so close to 140bhp at the crank is achievable. although I dont know how their appendix k setup compares to the miglia setup.
#14 A-Cell
A-Cell
  • 1,610 posts
Posted 05 September 2018 - 09:20 AM
The Metro drag coefficient was 0.4 versus round nose mini 0.51 and clubman 0.53.
Airflow over body shape has a big effect on the drag.
The HLE Metro (marketed as the economy version) had no rear mud flaps fitted to achieve the best economy as well as rear strakes and a higher final drive.
The external seams on the mini have large adverse affect as would wheel arch extensions...
#15 DeadSquare
DeadSquare
  • 3,197 posts
Posted 05 September 2018 - 09:58 AM
People used to go to a lot of trouble to "De-seam" a Mini.
I used to flatten the seam backwards with a hammer.
