Waterpump - Heater Air Temperature
16 replies to this topic
#1 dotmatrix
dotmatrix
  • 441 posts
Posted 05 September 2018 - 08:05 AM
I have a 998 Metro with a 12g940 head, a GWP187 waterpump, the small waterpump pulley (big one doesn't fit), no head-pump bypass hose, bypass through heater (as is normal on metros), an 88 degree thermostat and a renovated heater.
The problem I have is that in the winter the air out of the heater will only get lukewarm and not really hot and I suspect that this would be improved by using either a small impeller waterpump or the large diameter pulley (that does not fit) or maybe I can fit a smaller diameter crank pulley? Does any of you have experience with this?
Edited by dotmatrix, 05 September 2018 - 08:07 AM.
#2 nicklouse
  • 18,711 posts
Posted 05 September 2018 - 08:52 AM
More likely to be an air lock or internally blocked matrix.
#3 DeadSquare
DeadSquare
  • 3,201 posts
It might be worth making sure that the hose from the head goes to the top of the heater.
Another thought.   One like this, but check that it will withstand hot water
Caravan 12v In-Line Water Pump 14 LPM - COMET GEO IN-LINE PUMP
£24.95 Free postage
  • Get it by Sat, 8 Sep - Mon, 10 Sep from Bolton, United Kingdom
  •  • New condition
  •  • 30 day returns - Buyer pays return postage | Returns policy
In-Line Pump. Cable length 1m. We will always help you to have a 100% positive happy buying experience. You do not need an existing account in order to use this service. Add to Favourites.
#4 nicklouse
  • 18,711 posts
Posted 05 September 2018 - 08:54 AM
Why would you connect to the top heater connection? All you do is create an air trap.
#5 DeadSquare
DeadSquare
  • 3,201 posts
Posted 05 September 2018 - 09:00 AM
Not if you turn the tap off on the head, remove the hose and hold it up.
The heater fills from the bottom and pushes the air out of the top.
#6 dotmatrix
dotmatrix
  • 441 posts
Posted 05 September 2018 - 09:10 AM
Heater matrix is brand new and get very hot in the summer so dont think it is blocked or has and airlock
#7 dotmatrix
dotmatrix
  • 441 posts
Posted 05 September 2018 - 09:16 AM
I will check how the hoses connect to the heater. why would it matter in which direction the water flows through the heater matrix?
so your suggestion is to remove the mechanical pump and fit an electric? but how would I know how the flow of this pump compares to the flow of the mechanical?
#8 gazza82
gazza82
  • 3,021 posts
  • Local Club: TMF+
Posted 05 September 2018 - 09:29 AM
I think he means in addition ..
Mini heaters generally work ok so something is amiss with your flow ..
#9 dotmatrix
dotmatrix
  • 441 posts
Posted 05 September 2018 - 09:31 AM
yes I agree and my thoughts is the flow needs to be lowered, possibly in general and not just through the heater matrix
#10 DeadSquare
DeadSquare
  • 3,201 posts
Posted 05 September 2018 - 09:39 AM
Like the car rad before the war without a water pump, the water heats in the block, rises through the head, flows to the rad, cools, sinks and returns to the block;   the same is happening in the heater, coming in hot from the head at the top, cooling, sinking and returning to the block.
Keep the water pump, you will need it in the summer.  Insert the electric pump in the return between the heater and the block.
I did it on a girlfriends Hillman Imp to get more hot water from the engine in the back, so ought tho work on a Mini.
#11 russo
russo
  • 191 posts
  • Local Club: Minis In Nelson Inc.
Posted 05 September 2018 - 11:09 PM
Even though you have an 88 degree thermostat it may be opening too early, I suggest you test it or replace it.
#12 gazza82
gazza82
  • 3,021 posts
  • Local Club: TMF+
Posted 06 September 2018 - 09:16 AM
Although it works like that the heater matrix is enclosed so not getting the benefit of air flowing over it to cool it  So it will still be relatively hot/warm when it returns to the engine .. assuming that the heated coolant is getting through. It doesn't sound to me like that is happening.
Fitting an electric pump is simply masking the problem .. I used to get cooked in my mate's Mini ... the heater was too good. He eventually ran it with the tap on the heat partly closed even in winter .. although there were one or two days when it was open fully! (I agree it is probably useful on an Imp where the rad is a lot further away from the heater .. but on a Mini the hoses are relatively short.)
#13 Bat
Bat
  • 903 posts
Posted 06 September 2018 - 09:31 AM
Hi,
Is the thermostat fitted in the head or the sandwich plate?
Cheers  :proud:
#14 dotmatrix
dotmatrix
  • 441 posts
Posted 06 September 2018 - 03:37 PM
Hi,
Cheers :proud:
Yes the thermostat is on top of the sandwich plate :-)
#15 dotmatrix
dotmatrix
  • 441 posts
Posted 06 September 2018 - 03:39 PM
And the hot hose is connected to the top heater pipe
