Plug Welding Upside Down?
8 replies to this topic
#1 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 05 September 2018 - 11:05 AM
Just having a ponder. Can you plug weld from below or do you need gravity on your side to fill the hole?
#2 nicklouse
  • 18,601 posts
Posted 05 September 2018 - 11:14 AM
it is possible.
#3 Daz1968
Daz1968
  • 2,058 posts
Posted 05 September 2018 - 12:03 PM
It isn't too difficult I just find upping the power helps
#4 slidehammer
slidehammer
  • 1,196 posts
  • Local Club: LSMOC
Posted 05 September 2018 - 01:05 PM
Also upping the wire feed a notch when welding overhead helps and make sure you are well covers up as any spatter drops down on you!
#5 Bat
Bat
  • 903 posts
Posted 05 September 2018 - 06:19 PM
Hi,
Drill right through then put a piece of copper on the bottom and weld from the top...
Cheers  :proud:
#6 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 05 September 2018 - 07:50 PM
As has been said, power up slightly and wire speed up. Settings vary by welder so have a practice until you are happy.
If the weld finish is tall then it's unlikely you have enough penetration  so make sure those welds are nice flat domes (also much easier to grind back)
#7 weef
weef
  • 493 posts
Posted 06 September 2018 - 09:49 PM
Plug welds upside down are no problem. Turn up the welder to a high current/fast wire speed as normal for this type of joint and practice on test pieces to get the best results. Some welding machines have a timer facility which aids weld conformity but this is not essential as with a bit of practice good results can be obtained.
I drill a 5mm hole and use 0.6mm wire, cut the end of the wire to remove the "ball" every time and dress the swarf off from the back of the drilled holes.
Clamp the pieces tight and weld the joint as if you were welding from the top.
#8 MacGyver
MacGyver
  • 1,027 posts
Posted 07 September 2018 - 06:15 AM
Be weary of weld 'blobs' falling on you!
It hurts like he'll when in goes thru your trousers and boxers... ? trust me!
Happy welding!
Ben
#9 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 07 September 2018 - 04:58 PM
I've done normal welding upside down. Just though you had to fill the drilled hole with weld more.
