So, awhile back I had an issue where my upper rad hose burst and my car overheated. Because the temp sensor is in the intake manifold, it never gave me any indication that the motor was getting hot. It didnt help that it was pouring down rain so I could not see that all the water was escaping out. Since then I have installed a VDO electronic temp gauge and a sensor in the head, where earlier cars have them.
So, now I have the stock gauge and the VDO to reference and there is quite a bit of difference between the two. The cars gauge stays perfectly steady nearly all the time. (the sensor is newer and the manifold was completely cleaned out. Correct 88 thermo installed) While the stock doesn't move, the VDO seems to range from 82 and as high as 110c. Typically its around 93c (it reads in fahrenheit so I'm converting). Its been extremely hot here and during a long highway drive I notice it hit the 104 and then 110c mark. That seems too high, no? The rad is the newest style sold by Mini Spares and the aux fans works perfect. At 70mph on a 35c day, maybe I'm asking too much. Just want to make sure I am not doing any damage.
