Mpi Possible Boiling/over Heating
Posted 08 September 2018 - 08:07 PM
I have a 1998 mpi that has just been fully rebuilt by myself drove for the first time today after a event full week of mot tests. As a family we have owned the car for 20 years and have had minis last 15 years and never had issuses bleeding coolant system before!!!
The car is having a few teething problems I cant get any heat from the heater and have a slight leak from one connection I am concerned it is boiling the coolant aswell as is bubbling in the header tank not sure i have a good flow and is pressurzing the system???
The engine has had a full rebuild by myself new hoses water pump thermostat heater matrix and connections to matrix that have had rtv sealant put on to try help them seal?
I am getting to the point i have exhausted all my ideas flushing bleeding etc....
The fan kicks in and doesnt appear to be over heating from the temp gauge and have have checked the thermostat is working!!!
Hope i have explained myself properly any help would be greatly appreciated.
Cheers Ben
Posted 08 September 2018 - 08:26 PM
sounds like you have an air lock in the heater side of the system i would be looking at that. and look to bleed it separately.
Posted 08 September 2018 - 08:41 PM
Hi,
Is the hose after the heater valve getting hot?
Would be worth replacing the rad cap if you haven't already.
Posted 09 September 2018 - 11:08 AM
Always squeeze the big pipe in front of the rocker cover as you fill it up. Squeezing it pushed the air into the expansion tank. Make sure the heater vlave is open too.
Never had a problem with this technique (its the one form the Haynes Manual)
Q
Posted 09 September 2018 - 07:05 PM
I have ordered a new cap last night after reading some other topics similar to mine!!!
I have tried bleeding the the matrix separately return pipe off and running the car and i get good flow reconnected and topped up header tank!!
Have also run a hose pipe all different ways to make sure i dont have any blockage any where?
Starting to think i have more serious problems from the car and engine rebuild like a crack in the cylinder head or problem with one of the new components fitted water pump thermostat???
Will keep trying will get there in the end if anyone has any more ideas i am all ears.
Thanks for the flow diagram very helpful!!!
Posted 09 September 2018 - 08:17 PM
Is the thermostat located in the top of the sandwich plate, rather than underneath it?
Posted 10 September 2018 - 08:07 AM
