I just dropped my front subframe and I have two questions about it.
What could cause it to crack like this?
Is my only option to replace it?
Posted 09 September 2018 - 08:14 PM
Posted 09 September 2018 - 08:19 PM
yep that is what can happen with the front facing lower mount.
i would replace.
Posted 09 September 2018 - 08:24 PM
i would replace.
So is it a design flaw from the factory? I only had the car 18 months and havent really used it so was worrying that might have been in a bump
Thanks I thought was much, typical the rest of the frame is in okay condition
Posted 09 September 2018 - 09:39 PM
Posted 09 September 2018 - 09:49 PM
A friend of mine works on Minis professionally and I recall him doing quite a few of these, I think its quite common.
I would see if you can get a replacement, if not then welding it might work but you would need to plate it to give added strength or it will just break in the same place again (IMHO). Personally I would see repair as a last resort.
Posted 10 September 2018 - 07:51 AM
Posted 10 September 2018 - 09:45 AM
Some more piccies would be interesting to see how it relates to the bracket on the inside. It does seem odd that there's not obvious distortion suggesting it let go all at the same time. Rust in the seam?
I'd be wary of welding on plate to solidly or you may just move the stress riser along. Maybe plate to end as it's so near and 2 or 3 plugs to the other side, round means no sharp transitions for stress risers. Some people turn that cross-member in to Swiss cheese, apparently without causing similar failures.
Posted 10 September 2018 - 10:48 AM
Posted 10 September 2018 - 02:50 PM
looks like it's been sliced with a grinder !
Posted 10 September 2018 - 08:21 PM
i am wondering if it has been rewelded at some time.
Posted 10 September 2018 - 08:32 PM
Hi,
What bushes have been used in both steadies?
Posted 10 September 2018 - 08:49 PM
Posted 10 September 2018 - 08:50 PM
I have seen a few of these and you usually find the front teardrops are gone aswell. I have also seen a few welded and never seen one rebreak, sometimes a weld is stronger than the original. As you have it out of the car I would weld it unless you have access to another.
Posted 11 September 2018 - 07:43 AM
Thank you for all the replies, as mentioned I do not know a lot of the history of the car or when this has happened.
I have attached a few more pictures for you curious folk out there. I have budgeted for a new front subframe in my spend so I will just go with that, might be belts and braces but should i reinforce the new one prior to installing it?
Posted 11 September 2018 - 08:05 AM
an interesting image would be one looking at the weld from the "inside".
