Tire Pressure
11 replies to this topic
#1 croc7
croc7
  • 814 posts
Posted 14 September 2018 - 05:58 AM
With 10” A008’s, for street use, is there any reason to run a higher tire pressure than the recommended 28F/26R?
#2 cal844
cal844
  • 9,633 posts
  • Local Club: TFMOC
Posted 14 September 2018 - 01:28 PM
I'd start at 28 front and 30 rear, if you feel it's not right drop to 26/28
#3 Ethel
  • 26,022 posts
Posted 14 September 2018 - 01:39 PM
No, in a word.
Higher pressure should reduce the rolling resistance a little, but keep an eye out for uneven tyre wear.
#4 imack
imack
  • 2,176 posts
Posted 14 September 2018 - 01:56 PM
If I remember rightly from our old Michelin tyre pressure chart, the mini specials and early 80's mini sprites that were factory fitted with 165/70/10's were 2 psi lower all round than a 145/10, so 26 front, 24 rear.
This is what I run.
#5 nicklouse
  • 18,657 posts
Posted 14 September 2018 - 02:03 PM
I would never run higher at the rear.
for every day driving 28/26 is fine.
#6 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 14 September 2018 - 02:24 PM
oops, so 30psi (cold) all round on 10" Yoko AO32R (soft) is too much?
#7 cal844
cal844
  • 9,633 posts
  • Local Club: TFMOC
Posted 14 September 2018 - 02:45 PM
Generally 30 psi is about right imo, if you find it's too hard you can reduce as needed, also keep an eye on tyre wear.
All my minis are set differently
My 998(165/60/12 tyres)is on 26 all round due to very tired suspension components (it's getting restored soon)
My estate (145/10 Falken tyres) is set at 28 front and 30 rear
The 1275 Saloon(165/60/12 tyres) is at 28 and 30, if I need to I will drop the pressures to suit
Edited by cal844, 14 September 2018 - 02:47 PM.
#8 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 14 September 2018 - 03:19 PM
It feels fine, I adjusted the dampers a bit softer too (8 way), I know it sounds stupid but they always look flat-ish ie bulge at the bottom... compared to wifes car (E220) that are solid @34psi. 30 measured with accurate dial cold will do for now then on mine!
#9 Cooperman
  • 23,315 posts
Posted 14 September 2018 - 03:25 PM
I use 30 psi all round with A008's. It works well for me.
#10 cal844
cal844
  • 9,633 posts
  • Local Club: TFMOC
Posted 14 September 2018 - 03:29 PM
30 psi is what my friend runs on his A008 tyres, try it and go from there, if it's too hard, drop to 28 psi
#11 croc7
croc7
  • 814 posts
Posted 15 September 2018 - 03:18 AM
This is what I run.
#12 croc7
croc7
  • 814 posts
Posted 15 September 2018 - 03:26 AM
[quote name="imack" post="3560035" timestamp="1536933384"]
This is what I run.[/quote
Interesting- my Haynes manual quotes 1.7 bar, front and rear for the 165/70 x 10. Guess it comes down to handling and ride comfort.
