Popping Out Of 3Rd Gear
2 replies to this topic
#1 pakgorgor
pakgorgor
  • 91 posts
Posted 14 September 2018 - 08:41 PM
Hi,
My car recently developed a problem where it would jump out of 3rd gear. It only does it in 3rd, and only on deceleration, but not always.
I have renewed the engine stabilser rubbers and have checked the linkage (remote change). Everything looks to be in good order.
Any ideas?
#2 Swift_General
Swift_General
  • 871 posts
Posted 14 September 2018 - 10:05 PM
If you're happy it's not an external issue with linkage/engine mounts then could be a number of things inside the 'box, synchro unit/springs, dog teeth or selector fork. In any event the 'box will need to come out, and chances are you will find a number of other components that are worn and will require replacement I'm afraid.
#3 Spider
  • 15,201 posts
Posted 15 September 2018 - 06:17 AM
Just check that there's nothing silly like carpet or a bent shift rod preventing it going right in to gear, if that's OK then as Swiftgeneral has suggested, though, the other thing it can be from is a worn Mainshaft Bearing too.
