Knocking On Rocker Cover
4 replies to this topic
#1 Chesty2925
Chesty2925
  • 88 posts
Posted 15 September 2018 - 06:50 PM
I drove the mini today when it started to shudder and the exhaust fell off. I got it home and when listening to the engine it sounds like a cylinder is off. Also when you feel the rocker cover you can feel the rockers knocking.
Any ideas?
It has been running lean too.
#2 Spider
  • 15,684 posts
Posted 15 September 2018 - 08:06 PM
I'd suggest taking the rocker cover off for starters and having a look for tell tale marks in it of contact from the rockers.
You could have had a rocker adjusting screw come loose and wound out, or a broken rocker shaft.
Or, it maybe something else altogether.
#3 speedwell1
speedwell1
  • 107 posts
  • Local Club: m4 minis
Posted 16 September 2018 - 04:01 PM
I had a similar problem once, rattling inside the rocker cover, one of the adusting nuts had made itself loose and was knocking around inside,
#4 Chesty2925
Chesty2925
  • 88 posts
Posted 16 September 2018 - 08:52 PM
Cheers I will have a look and check
#5 russo
russo
  • 191 posts
  • Local Club: Minis In Nelson Inc.
Posted 16 September 2018 - 09:36 PM
Alloy rocker cover or standard metal one? Alloy ones are prone to touching especially if 1.5 rockers fitted.
