Noisy Alternator
7 replies to this topic
#1 germini30
germini30
  • 722 posts
Posted 15 September 2018 - 07:45 PM
My alternator is noisy. Sounds like a bearing noise. Is there anything I can do or will it be a new item. 1989 mini 1000.
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 15 September 2018 - 08:38 PM
Fairly easy bearing change if needed. Got a picture?
Ac
#3 Bat
Bat
  • 903 posts
Posted 15 September 2018 - 08:39 PM
Hi,
You could strip it down and fit new bearings.
Cheers  :proud:
#4 Spider
  • 15,684 posts
Posted 15 September 2018 - 08:58 PM
Does it get louder with the headlights on?
Could also be a rectifier.
#5 timmy850
timmy850
  • 3,560 posts
  • Local Club: MITG
Posted 16 September 2018 - 12:10 AM
Are you sure it's the alternator? You could try running the car without the belt to make sure it is the alternator. You can also spin the water pump and alternator by hand to see if they are making strange noises or are wobbly
#6 germini30
germini30
  • 722 posts
Posted 16 September 2018 - 06:51 AM
Here are some photos
#7 Bat
Bat
  • 903 posts
Posted 16 September 2018 - 07:17 AM
Hi,
They're easy enough to repair. In the second picture the lump to the right of the plug, with 2 bolts in, is the regulator.
Take that off carefully so you don't break the brushes off it.
Then take the pulley and fan off, remove the 3 long bolts and strip it all down.
Swap the bearings and rebuild.
That's a rough outline, but if you've got the time and was planning on buying a new one there's no harm in having a go...
Cheers  :proud:
#8 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 16 September 2018 - 11:30 AM
It's an A127, I can fit a pair of bearings for £20. It is rather old now I would simply rebuild it fully or have it rebuilt.
Ac
