Outer Sill Welding Quote
Posted 16 September 2018 - 02:57 PM
I have just been given a quote for welding the outer sills on my H reg mini.
I need to buy the panels but the quote is £400
Is this about right ? I have no idea.
Thanks all
Posted 16 September 2018 - 03:34 PM
Also ensure correct type of sill is fitted
Posted 16 September 2018 - 03:45 PM
what sills are they -
don't bother if they are oversills as they seem to create rust & cover it up
Posted 16 September 2018 - 03:58 PM
They're cover sills, good for a quick fix but will cause misery further down the line. Get the standard 4 inch sills fitted
Posted 16 September 2018 - 04:07 PM
Thank you
Posted 16 September 2018 - 04:33 PM
Posted 16 September 2018 - 04:42 PM
Posted 16 September 2018 - 04:50 PM
Posted 16 September 2018 - 06:05 PM
To be honest i would chin off Magnum sills period. Try these from M Machine, far better quality
14.32.00.01 Sill, LH, Mk3-on, 6 Flute £19.00 £22.80
14.32.00.02 Sill, RH, Mk3-on, 6 Flute £19.00 £22.80
Now price wise, one hour to take off old sill and clean up. (2 hrs total)
Prep replacement sill, so etch prime, prime and top coat. One hr per sill. (two hours total.)
Now providing its a reputable garage, they will have spot welding equipment, so another hour each side (two hours total)
Paint, now i would do this myself.
So at least six hours worth of work. Now i'm not sure what hourly rate garages charge but say £40 ph then £240.
£200 a side without doing anything else sounds rich to me but then i do all my own.
Posted 16 September 2018 - 06:26 PM
I would pull the carpet off and check the inner sill, floors and inside the rear companion bins. If they are looking suspect then there won't be too many additional surprises when the outer sills come off. Check with the garage to see if the quote has allowed for a small amount of additional work that they couldn't possibly have seen when quoting. You want some mutual understanding with the garage before they take them off, call you up and you fall out lol.
Edited by DeanP, 16 September 2018 - 06:27 PM.
Posted 16 September 2018 - 06:30 PM
I am getting another quote next week so will see how that prices up.
As for the sills I will get the ones you recommended
Thank you ;)
