Jbw 10" Rose Petal Wheels - Fit Without Arch Extensions?
6 replies to this topic
#1 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 20 September 2018 - 02:38 PM
As per title really.
Car is a late model (MPI) with Cooper S front disc conversion. Currently on S offset Minilite replicas, but fancy a set of Rosepetals to mix things up a bit. I've seen pictures of them fitting on early cars with no arch extensions, but don't know if the originals are the same offset as these ones that JBW sell.... link below.
http://www.johnbrown...rose-petal.html
Cheers!
Rich.
#2 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 20 September 2018 - 02:43 PM
They definitely should do at 4.5" wide, they're supposed to be the correct offset to not need arches.
Just to add, the minispares version, even though a lot more expensive, are better in quality.
Edited by GreaseMonkey, 20 September 2018 - 02:44 PM.
#3 Cooperman
  • 23,356 posts
Posted 20 September 2018 - 04:34 PM
You won't need arch extensions with those wheels.
#4 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 21 September 2018 - 09:49 AM
Cheers grease monkey & cooperman. Those in my link say 4.75" so a bit wider (and +40 offset) so wasn't sure how they'd sit.
I'll check out the minispares version too - didn't realise they did them. Thanks again.
#5 gazza82
gazza82
  • 3,025 posts
  • Local Club: TMF+
Posted 21 September 2018 - 10:44 AM
Sounds like someone at JBW can't measure a rim correctly!
#6 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 21 September 2018 - 11:13 AM
Minispares says 4.75" too. And that a spacer is supplied/required to clear disc and caliper (or modification to disc and caliper without the spacer). So sounds like they are a little wider - presumably inboard with the offset? So less of an arch coverage issue and more of an internal clearance one?
Don't really want the spacers or the modifications so I'll probably just paint a set of S offset minilites matt black for a similar look!
#7 GreaseMonkey
GreaseMonkey
  • 3,663 posts
Posted 23 September 2018 - 09:44 AM
Strange, I seem to remember them being advertised as x4.5 before?! They are designed to fit without arch extensions though, so I'm confident you will be fine. The spacer is to clear the disc setup.
