Tappet Chest Gasket Leaking
5 replies to this topic
#1 SKIDDERWOLF
SKIDDERWOLF
  • 301 posts
Posted 21 September 2018 - 07:49 PM
As title, have fitted new gaskets to cleaned faces but still have oil leaks. Any tips to get these to seal well - should I be using some type of sealant?
#2 Wiggy
Wiggy
  • 1,036 posts
Posted 21 September 2018 - 07:55 PM
If you over tighten them, they'll warp and leak. Or if they've previously been over tightened.
#3 mk1leg
mk1leg
  • 9,343 posts
Posted 21 September 2018 - 08:09 PM
have you put new bolt seals http://www.minispare...px|Back to shop
#4 SKIDDERWOLF
SKIDDERWOLF
  • 301 posts
Posted 21 September 2018 - 08:21 PM
Have new bolt seals, they are leaking from the lower edge I can see oil on the block below. How tight should they be.? I did not Crank them mega tight.
#5 Swift_General
Swift_General
  • 871 posts
Posted 21 September 2018 - 08:25 PM
Not very. Factory manual states 3-4 lb ft. So outside the range of a typical torque wrench.
Edited by Swift_General, 21 September 2018 - 08:27 PM.
#6 SKIDDERWOLF
SKIDDERWOLF
  • 301 posts
Posted 22 September 2018 - 08:20 AM
Thanks, will recheck
