Help - Smoke Coming From Fuse Box
Posted 22 September 2018 - 05:06 PM
Posted 22 September 2018 - 05:13 PM
Posted 22 September 2018 - 05:34 PM
as above , or fuse box corrosion
first Isolate battery remove fusebox ,
look at the back for scorching / melted plastic
If it all looks good , then I would carefully split the loom on the off side wing & look for melted wires
pink & white is the ballast wire - prone to corrode crack & get hot then fail
also worth checking the main red battery cable under the car , check it is in good condition
and hasn't rubbed on the sub-frame , or any other bits of metal under there
also check earth cables are good & well connected & choke throttle cable aren't getting hot
best of luck - hope it is a cheap fault
Edited by sledgehammer, 22 September 2018 - 05:36 PM.
Posted 22 September 2018 - 06:12 PM
Started it up again and fired straight up no smoke. It’s an MPI by the way if that helps anyone to disect the problem if it happens again on the way home... but hopefully that was the issue.
Posted 22 September 2018 - 08:34 PM
Posted 23 September 2018 - 09:18 AM
Posted 23 September 2018 - 09:30 AM
Posted 23 September 2018 - 09:44 AM
Pull each fuse and look for a 'witness mark' on the fuse or carrier, that should help you start looking in the right direction.
Good luck.
