Tight Spot On Crankshaft
13 replies to this topic
#1 Mini_Problems_
Mini_Problems_
    Formally known as Cmontgomeryc
  • Just Joined
  • 46 posts
Posted 24 September 2018 - 08:03 AM
Currently assembling my short block, the crank has been ground 10 thou on mains and big ends, however when installed with new plus 10 shells there is a very slight tight spot during rotation.im not talking much but noticable, otherwise it spins freely between my fingers. I have found score marks on the centre bearing, this was either dirt or something rough on the crankshaft.i have polished the crank but still the same problem, currently waiting on new shells. Has anyone got any ideas, or could this slight tight spot be acceptable.A Dti is on its way to test run out, Tia
Edited by Cmontgomeryc, 24 September 2018 - 08:04 AM.
#2 Icey
Icey
  • 1,554 posts
Posted 24 September 2018 - 08:28 AM
It sounds like one of the journals is out-of-round. If you have a micrometer, either metric or imperial (with 10ths) then you can double check. If that's true then you need to go back to the grinder.
#3 mini13
mini13
  • 3,811 posts
Posted 24 September 2018 - 08:41 AM
Pics would help, but I'm thinking a burr on the oilway, or some debris that's come loose.
A ghetto check (as you already have scored the bearings) would be to use a permanent marker on the journel to show a high spot when rotated
#4 mini13
mini13
  • 3,811 posts
Also could be a bend in the crank
#5 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 24 September 2018 - 08:45 AM
There should be no marks on any of the journals and certainly no scoring
If you can see anything or feel anything it needs to go back to the machine shop
As above it needs checking for round and taper, but scoring is debris or damage from something
All the drillings need cleaning out again, block and crank
It also needs checking for straightness preferably whilst in the block
#6 Spider
  • 15,201 posts
Posted 24 September 2018 - 08:59 AM
If it's scoring, then there's something there that shouldn't be.
It's quite easy to have a contaminate in there. When you clean it all, clean it again, and even then, it won't be clean enough. I do use a Kerosene based cleaner in my engine cleaning bath, but that's only for a 'preliminary' clean. One up side is it does leave an oily film so parts have some protection from rust, likewise, the down side of it is it leaves an oily film that captures dust very easy.
Following this preliminary clean, I clean the parts again with Paint Thinners as this leaves no residue and is very clean, the down side being, they need oil in short time or certain times of the year, they'll begin to rust before your eyes.
When fitting the Bearing Shells, they are slightly expanded in size from the tunnel size. When fitting them, the backs inevitably scrap on the block, which can cause shaving of the shell back. Some of these shavings can end up between the shell and the block, distorting the shell and causing it to rub on the crank.
When the crank is re-ground, the grinder man should as part of that process, enlarge the chamfers on the journal surface where of the Oil Way Drillings. This is usually done by hand with a die grinder and it is possible that one of these may have a bur from this process.
#7 Mini_Problems_
Mini_Problems_
  • Just Joined
  • 46 posts
Posted 25 September 2018 - 11:48 AM
Thankyou for all your replies I will get a dti on it and check for out of round. The permanent marker idea seems pretty good too :) I'll send d itback if I find anything cheers
#8 carbon
carbon
  • 2,590 posts
Posted 27 September 2018 - 06:43 PM
Good suggestion, and I would be surprised if DTI picks up out of round journals unless the regrind has been spectacularly incompetent.
Here is suggested check for bend in crank when you have the DTI available:
- assemble crank (no rods) into crankcase with only the two end bearings. no cap or shells for centre
- first see if crank rotates easier with no tight spots
- then if running free put DTI on centre main journal (avoid oilway) and rotate, checking DTI for runout at centre main
About 1 thou runout is unlikely to cause issues. 2 thou or more likely needs corrected.
#9 DeadSquare
DeadSquare
  • 3,205 posts
Posted 27 September 2018 - 07:19 PM
The crank has been reground, so surely, if there was a bend in it, it will have resulted in more being taken off one side than the other and the crank now being "true", but less 'in balance'.
#10 Spider
  • 15,201 posts
Posted 27 September 2018 - 07:49 PM
All good suggestions, however, if I can suggest, at 1 thou run-out, there will likely be an issue. Running clearance is 0.001 to 0.0027". From what I see, most Crank GrInders tend to go for the tighter limit (o.001") when grinding (I wish they wouldn't), so at 0.001" run-out, all the clearance will have been eaten up.
Although these are very small numbers, they need even more care. Eg, a crank with 1/2 a thou run-out has 50% of the bottom end of the range of clearance taken away.
I think in all fairness, we need to see some photos.
#11 DeadSquare
DeadSquare
  • 3,205 posts
Posted 27 September 2018 - 09:30 PM
OK, so if my idea that the grinding would result in a true shaft, doesn't work, and the shaft is bent, as it rotates, it is going to rub all the way round, not just in one place.
#12 carbon
carbon
  • 2,590 posts
Posted 27 September 2018 - 09:48 PM
It also depends on the alignment of the main bearing housings.
#13 Spider
  • 15,201 posts
Posted 28 September 2018 - 01:40 AM
Also, if it really is bent (and that's not at all unusual to find), it's always best after confirming that's the case, to straighten it 100% before re-grinding, otherwise, the flywheel will really whip around big time, making matters worse.
When checking for a what appears to be a bent crank, especially if it's ever been re-ground, the Nose and in particular, the Tail should also be checked for run out. If these have run-out, then the crank is bent, if however, the Centre Main has run-out and the Tail doesn't, then somewhere it's most likely had a poor grind job done.
#14 Cooperman
  • 23,347 posts
Posted 28 September 2018 - 10:25 AM
Crankshafts all have some tolerances. In fact there are several in addition to the journal diameters.
They are straightness, stroke and index.
Some crank grinders can only re-grind on existing centres, so tolerances (inaccuracies) will still be as they were.
However, more well-equipped machine shops can straighten, stroke and index a crank. This is usually done with top performance cranks for competition engines. The main bearings are all re-ground on an accurate centre-line, then the big end journals are ground to be exactly the correct and identical stroke and at the same time journals 1 & 4 are ground to be exactly 180 degrees opposite from 2 & 3. Hence straight, stroked and indexed.
Accurate it is, but cheap it ain't! My Cooper 'S' has such a crank which is, of course, also fully balanced as a bottom end assembly.
It can be surprising how far out even a brand new A-Series, or A+, crankshaft can be.
