Is that about right?
Edited by johnR, 30 September 2018 - 01:30 PM.
Posted 30 September 2018 - 12:37 PM
Posted 30 September 2018 - 12:51 PM
No.
When I had the 850 engine in mine it was quicker than that.
Posted 30 September 2018 - 01:19 PM
Posted 30 September 2018 - 03:48 PM
Hi,
Paint if red then, it's always worth an extra 10 bhp!
Posted 30 September 2018 - 04:20 PM
Generally a bog standard 998 should hit 60 in a shade over 21 seconds.
Although if it's your first car, in your mind you KNOW it does it in 16 seconds, 15 if the engine's red
Posted 30 September 2018 - 07:03 PM
An original 850 Mini did 0 - 60 in between 24 and 27 seconds.
A 998 Cooper took c.15 seconds.
Posted 30 September 2018 - 07:50 PM
Posted 30 September 2018 - 09:44 PM
Isn’t a City E spec box fitted with a higher final drive so would typically be slower accelerating anyway?
Hi,
I believe you may be correct. It would be best to check the specs to get the correct information...
Edited by Bat, 30 September 2018 - 09:45 PM.
Posted 30 September 2018 - 09:48 PM
Posted 30 September 2018 - 09:49 PM
Posted 30 September 2018 - 10:04 PM
No.
[/quote]
How much quicker? I have City E gearbox and the engine's not painted red.
850 engine, it was about 20 seconds 0-60
Posted 30 September 2018 - 10:23 PM
City E's had 2.95 diffs. It shouldn't make a massive difference as you can go faster before changing up. You could probably get to 60 quicker in 3rd.
Posted 01 October 2018 - 08:21 AM
With engine replacement imminent I've just tested the 0 - 60 time in my standard 1989 998 mini on 10" wheels - 35 seconds!(SatNav)
more here;-
http://www.automobil...ini_v/1989.html
I think there's something not at all right with your Mini, it should go well better than what you are experiencing. I'd suggest starting with a decent tune up, that will also check the 'health' of the engine.
Posted 01 October 2018 - 11:05 AM
I timed my Cooper 'S' using a calibrated speedo and 0 - 60 was 7.3 seconds using just 1st & 2nd, and 7.9 using 1st, 2nd & 3rd.
I have a SCCR gear box and a 3.9:1 FDR. Just using 1st & 2nd meant using about 7300 rpm.
