Camshaft Nut Removal
10 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 03 October 2018 - 06:26 PM
Hi;
What's the correct way to remove the CamShaft nut, the one that holds the timing gear on?
I have removed the Flywheel and split the engine but don't know the best way to stop the Cam from rotating to hold the nut.
Is it a 1 and 5/16th Nut?
Many thanks
#2 nicklouse
  • 18,593 posts
Posted 03 October 2018 - 06:33 PM
block of wood between crank and block. same as steering wheel nut, crank bolt. hub nuts and big subframe bolts.
#3 imack
imack
  • 2,110 posts
Posted 03 October 2018 - 07:27 PM
I tend to tighten/loosen them while the flywheels still on and lock the ring gear.
If flywheel is off - as nick suggested.
#4 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 03 October 2018 - 08:50 PM
Thanks block of wood not is then.
#5 Dusky
Dusky
  • 5,322 posts
Posted 03 October 2018 - 09:27 PM
Screwdriver through a hole in the gear and lever on one of the 3 cam plate nuts. Saw it on a minimania video and used that trick ever since.
#6 Bat
Bat
  • 903 posts
Posted 03 October 2018 - 10:31 PM
What he said  :proud:
Always use the most direct method. Wedging the crank with a block of wood is putting the strain through the timing chain .
Cheers  :proud:
Edited by Bat, 03 October 2018 - 10:33 PM.
#7 Cooperman
  • 23,286 posts
Posted 04 October 2018 - 04:19 PM
what I do :D .
#8 carbon
carbon
  • 2,590 posts
Posted 04 October 2018 - 04:29 PM
Electric rattle gun also works wonders on a tight camshaft nut. And as long as chain is in place you don't need to wedge anything.
Because the nut is so thin find it best to use a very close fitting socket.
#9 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 04 October 2018 - 08:11 PM
What size is the nut?
#10 Swift_General
Swift_General
  • 871 posts
Posted 04 October 2018 - 08:46 PM
1 5/16"
#11 Cooperman
  • 23,286 posts
Posted 04 October 2018 - 11:00 PM
I never over-tighten that nut because of the grief it would give if the thread stripped. I just 'nip' it up, using Loctite and the lock washer.
The only time I had a problem doing this was quite recently when an after-market sprocket had the slot for the key too wide and the sprocket moved slightly on the cam causing a nasty rattling noise which alerted us to the issue.
