Later Lock Barrel In Early Boot Handle?
8 replies to this topic
#1 johnR
johnR
  • 2,299 posts
Posted 07 October 2018 - 09:32 PM
As above - I want to have single key access but I have push button door handles and a Mk1 boot handle. Looking at Minispares replacement barrels listing the early and late boot handle barrels look the same so can I interchange them? if so I can take the barrel out of the later boot handle that came with the door handle set and fit it in the early 'T'handle?
Edited by johnR, 07 October 2018 - 09:35 PM.
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,032 posts
Posted 07 October 2018 - 09:34 PM
Yep done it on mine, bought a new set of mk3 door handle and mk3 boot handle and swapped the boot handle barrel to a mk1.
#3 johnR
johnR
  • 2,299 posts
Posted 08 October 2018 - 09:27 AM
Great, many thanks for confirmation.
How did you re-secure the Mk1 barrel - the original system being the crimping on the square rod?
I'm thinking drilling and fitting a rollpin would be more secure than the original?
Edited by johnR, 08 October 2018 - 11:01 AM.
#4 GraemeC
GraemeC
  • 7,439 posts
Posted 08 October 2018 - 07:19 PM
Why do you need to remove the square rod?
#5 alex-95
alex-95
  • 6,032 posts
Posted 08 October 2018 - 07:24 PM
I can't remember what I did now, don't remember having to fit a pin though
#6 GraemeC
GraemeC
  • 7,439 posts
Posted 08 October 2018 - 07:31 PM
Me neither, I can’t remember removing the shaft either.
OP - In your photo it looks like the old barrel has been removed, without removing the shaft?
#7 johnR
johnR
  • 2,299 posts
Posted 08 October 2018 - 09:47 PM
That's correct - but the handle is secured to the car by the crimp in the square rod holding the chrome cup (bottom right) which secures the mounting block with the captive threads that bolt it to the bootlid. You can't get the barrel out without removing the little brass pin that I've left sticking out of each carrier. Those pins are covered by the chromed blocks that bolt to the lid. On the newer ones the one spring pin does both jobs.
Hope that makes sense!
#8 GraemeC
GraemeC
  • 7,439 posts
Posted 08 October 2018 - 09:58 PM
I don’t remember the crimped bit on mine, but it was 10 years ago. But I certainly didn’t drill and pin anything.
Maybe mine had a circlip rather than the crimp.
#9 johnR
johnR
  • 2,299 posts
Posted 09 October 2018 - 08:39 AM
Something like that would have been a lot easier!
