What Does Lower Arm Ball Joint Do And What Does It Look Like?
4 replies to this topic
#1 Minisport7
Minisport7
  • 73 posts
Posted 09 October 2018 - 05:06 PM
My Mini Cooper sport (1275, w-reg) has failed MOT due to ‘Front Lower Suspension arm ball joint excessively worn‘.
What does this part look like and what is it’s function?
Thanks!
#2 Swift_General
Swift_General
  • 871 posts
Posted 09 October 2018 - 05:19 PM
Here's a link. They are adjustable via shims, to a point. If worn irregularly as often happens it will need replacing. It sits at the bottom of the hub, connecting it to the bottom arm.
https://www.minispar...px|Back to shop
Edited by Swift_General, 09 October 2018 - 05:22 PM.
#3 Minisport7
Minisport7
  • 73 posts
Posted 09 October 2018 - 05:40 PM
Thank you!
#4 greenwheels
greenwheels
  • 690 posts
  • Local Club: Mini Fixers
Posted 09 October 2018 - 05:53 PM
Always a good idea t select an MOT garage that will test 'while you wait' and if there are any problems will show you where and what they are they are. They have a certain amount of time allocated by the MOT authority and Minis don't take long to MOT so they have plenty of time to explain what they found. That's good customer service.
#5 matt615
matt615
  • 923 posts
Posted 09 October 2018 - 06:06 PM
Totally agree with this.
There is a MOT only place that opened near me 3 years ago. I now take both Minis and both normal cars there. Done promptly while you wait, and a completely honest pass or fail with no hidden agenda to create work.
If it does fail they invite me under the car on the ramp, and demonstrate exactly what the problem is. Then you get two weeks to come back for a free re test.
That’s the way MOTs should be.
