Hi all,
ok, new callipers, new rear drum cylinders, rebuilt master cylinder and untouched bias valve.
I have no leaks anywhere, hence the new callipers and cylinders.
I have been using an Eazi Bleed kit and bleeding furthest to nearest master cylinder in turn.
I have bubbles coming out and have repeated the process 4 times now.
Here's what I get after each attempt...
No pedal, hits the stopping point, but then I start to get firmness when pumped. This is low down the pedal travel and with as much force as I can I can get the pedal to hit the stopping point, but it hard. After leaving it for a little while I am back to the no pedal situation, as it air is leaking back in !!
I have checked every joint, all dry, the new callipers and rear drum cylinders after the 4th attempt, all dry.
The master cylinder seal is ok and I have tried sealing it with tape to see if that is leaking air, but same problem.
Where do I go from here???
Regards,
Graham
