Water Pump - Bypass Or No Bypass
26 replies to this topic
#1 Readers14
Readers14
  • 441 posts
Posted 22 October 2018 - 11:21 AM
I am carrying out a complete overhaul of the coolant system, as I noticed a leak a few weeks ago.
Looks like the leak is coming from the bypass hose.
I'm replacing all hoses, thermostat, thermostat housing and water pump.
So, what is the general consensus - Water pump with bypass or not?
Car is 1994 Mini Sprite, 1275cc. Had no previous cooling problems.
#2 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 22 October 2018 - 11:23 AM
I thought if you had no bypass anywhere the pump would terminate itself trying to push water that can't go anywhere?
My car has a Metro engine that has no bypass, so runs wit the heater permanently on as that circuit is the bypass.
#3 nicklouse
  • 18,742 posts
Posted 22 October 2018 - 11:24 AM
they are not needed. but if you have the pump off a quality hose there is better than the nasty concertina version.
#4 ukcooper
ukcooper
  • 1,625 posts
Posted 22 October 2018 - 11:47 AM
water problem on a mini 99% of the time its head gasket...try a compression test thotle open all puhd out cold or warm your looking for the same ruff compression on each cycinder eg 100  100  100 100
any engine job i replace the water pump as good prctace, hose pipe evry 3 years with coolent , and all the rest.
and clean the matrix out replace every 5/6 yearshets full off crap - i dont get many vreak downs ... lol..
id go with the bypass as you will have block rge hole in the head and it not easy with the head on
Edited by ukcooper, 22 October 2018 - 11:54 AM.
#5 Cooperman
  • 23,357 posts
Posted 22 October 2018 - 12:03 PM
If possible delete the by-pass hose and block or blank off.
#6 Readers14
Readers14
  • 441 posts
Posted 22 October 2018 - 03:20 PM
I don't have a problem with the head gasket. It's leaking from the bypass hose.
I can see a split in the hose.
I have removed top & bottom hoses & radiator, then flushed them out plus flushed the head/block with a hose.
#7 Readers14
Readers14
  • 441 posts
Posted 24 October 2018 - 07:12 AM
Ok, so I decided to go down the no bypass route.
Next question is - minispares sell a plastic impeller version. Is this any better than the normal metal impeller?
I think the plastic one works out to be cheaper than the metal one.
#8 imack
imack
  • 2,221 posts
Posted 24 October 2018 - 06:53 PM
I've been using one of minispares plastic impeller 'super evo' pumps for a couple of years now with no issues.
Given the choice I'd run with a bypass hose fitted. I've never had a decent quality bypass hose leak in over 34 years of mini ownership, having said that, I've always replaced the bypass hose thats more than a few years old if I've had the head or pump off.
I've had a couple of heads without the bypass hose, couldn't get the blanking plug out of my current head so it has no bypass hose and I find the engine takes forever to warm up in cooler weather even with just the one small hole in the stat with the jiggle pin thing in it.
Wish I had a bypass hose.
#9 Readers14
Readers14
  • 441 posts
Posted 24 October 2018 - 09:41 PM
Thanks for that.
My Mini only comes out during the summer months, as it’s taken off the road during autumn & winter.
So it doesn’t get regular use & when it does, the ambient temperature will be warm enough for the engine to get to operating temperature fairly quickly.
#10 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 24 October 2018 - 09:52 PM
Hi. Those concertina hoses are indeed, utter utter rubbish.
I've always used the Minispares kevlar re-inforced Bypass hose, no leaks and doesn't split. but you'll have to pull the W/pump to fit it.
Here - > follow this link  http://www.minispare...ypass hose.aspx
#11 midridge2
midridge2
  • 1,794 posts
Posted 25 October 2018 - 06:21 AM
The concertina hose is just a emergency hose to be used temporary.
#12 Readers14
Readers14
  • 441 posts
Posted 25 October 2018 - 06:31 AM
So what exactly is the purpose of the bypass hose?
#13 Readers14
Readers14
  • 441 posts
Posted 25 October 2018 - 07:44 PM
Ah ha! http://www.dsnclassi...coolant-bypass/
#14 nicklouse
  • 18,742 posts
Posted 25 October 2018 - 08:46 PM
not quite correct as when you turn the heater off on the later minis you stop the flow.
again you do not need the bypass. the water flows and the thermostat opens.
#15 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 25 October 2018 - 10:31 PM
Please elaborate.........
Every A series engine that was installed at the factory since the 1950's was fitted with a thermostat bypass of some description. The 'later Minis' are no exception.
