And when I do get it registered what Make am I going to say it is? In Australia, a general rule is that if it's a round nose it's a Morris if it's a square nose (clubman) then it's a Leyland. Being UK built do I call mine a British Leyland, Leyland, or BMC, or Morris? Thanks
1972 it would officially be a British Leyland - Mini 1000 on registration documents, although many were still recorded as BMC/Austin/Morris, etc by Dealers when filling out hand written registration forms, etc......Austin and Morris was dropped from the UK market Mini range with the introduction of the Mk3 in 1969 and 'Mini' became a standalone brand under British Leyland (BLMC). The Mk3 Mini also had small blue/silver BL badges on each 'A' panel in the 1970's.
Part No. CZH657 Silver on Blue (Embossed) stick-on badge was used between 1969 and 1971. It was stuck to both A-panels.
Part No. CZH2717 Blue on Silver (Printed Flat) two pin fixing badge was used between 1972 and 1975. Later it changed to only being fitted on the left side A panel. There is an August 1975 dated BL brochure that shows Mini's with badges on the left and no badges on the right side.....
CZH657 HOUSE BADGE, 'British Leyland', silver on blue 2 1969-71; self-adhesive. Applied to both A panels.
CZH2717 HOUSE BADGE, 'British Leyland', blue on silver 1 1972-75; push fixing. Applied to passenger's side A panel.
Above from the Somerford parts lists.
Edited by mab01uk, 25 October 2018 - 10:19 PM.
