Is There Such A Thing As Inlet Valve Seats?
13 replies to this topic
#1 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 24 October 2018 - 09:00 AM
Hey all.
Considering rebuilding my head in the not too distant future. I'm unsure if my head has unleaded seats, so I figured I'd put new ones in anyway.  I can find exhaust valve seats for my 998 A+, but not inlet ones.
Is there such a thing as a replacement inlet valve seat? Or you're stuck with whats on your head?
I sent a question to minispares, but got a reply saying there's no such thing as inlet valve seats.
#2 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 24 October 2018 - 09:10 AM
Its only the exhaust that needs the hard inserts
The exhaust valve gets a lot hotter than the inlet and even the valve itself can burn.
Some turbo exhaust valves are sodium filled to help carry heat away from the valve head to the guide
#3 Spider
  • 15,245 posts
Posted 24 October 2018 - 09:11 AM
As Retroman has said in your case, but if due to wear, you find you need Inlet Seat, yes, they are available.
#4 nicklouse
  • 18,757 posts
Posted 24 October 2018 - 09:17 AM
yes you can have replacement seats on the inlet as well as the exhaust. but there is little point. just lap them in o have them recut if needed.
#5 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 24 October 2018 - 09:24 AM
When they are machined they need an interference fit of about 0.0045"
And need cooling with liquid nitrogen to get them in
If not they can fall out, which is not nice
#6 nicklouse
  • 18,757 posts
Posted 24 October 2018 - 09:36 AM
had that happen on one of my builds. trashed one Omega piston. gained an Ashtray.
#7 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 24 October 2018 - 09:46 AM
The factory unleaded heads had all 8 done. I can't actually say they all did but my one certainly has
#8 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 24 October 2018 - 10:04 AM
We had one too, it was early days of unleaded, batting down the 3rd lane after an SR Nova
Just got a massive rattle, and were lucky the seat was still round the valve
#9 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 24 October 2018 - 11:09 AM
As above, it's only really required on the exhaust side. It is possible to insert the inlet side but there's little point.
I've never seen a factory head with inserts on all the valves. Though I guess anything's possible knowing BL/Rover.
Phil.
#10 ACDodd
ACDodd
  • Mini Docs
  • 2,769 posts
Posted 24 October 2018 - 05:06 PM
The standard factory A+ 998 head has inlet valve seat inserts as well as the exhaust.
Ac
#11 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 25 October 2018 - 07:14 AM
Aha, there we go. They must have dabbled with the 1275 too. 1992 my one with all 8 done
#12 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 25 October 2018 - 08:39 AM
Ac
is it ever necessary to change these to hardened seats and if yes where can I get them?
#13 ACDodd
ACDodd
  • Mini Docs
  • 2,769 posts
Posted 25 October 2018 - 11:16 AM
No, not necessary.
Ac
#14 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 25 October 2018 - 10:03 PM
Ac
Not doubting your wisdom AC, but there must be a exception to this rule, as I've had factory unleaded 998 heads with ex inserts only before.
Phil.
