Towing Eyes?
18 replies to this topic
#1 Bobbins
Bobbins
  • 1,512 posts
Posted 30 October 2018 - 10:35 AM
My 1998 JDM Cooper has two front towing eyes permanently fitted, it was that way when I bought it. Is this just a quirk of the Japanese market models or will it be something a previous owner has done?
Also, both towing eyes are different, one is threaded externally and fastened in place with a nut, the other is threaded internally and held with a bolt and a selection of spacer plates and washers ... this doesn't make sense unless there's something I'm missing? IIRC the parts diagrams show this to be correct.
I've no particular desire to have the towing eyes in place although I am trying to keep the car original, two does seem overkill though.
Stu.
#2 nicklouse
  • 18,696 posts
Posted 30 October 2018 - 10:54 AM
yep there are two versions as standard. the rope one was standard on Export cars (mainly Europe) and the other came about on the MPI cars (JDM SPi)
http://www.minispare...owing eye .aspx
I guess yours lost one at one time.
and back in the day we really wanted the "rope" ones on our Minis as they were rare.
#3 Bobbins
Bobbins
  • 1,512 posts
Posted 30 October 2018 - 04:52 PM
If I remove them both I assume I'll need to replace them with suitable bolts/nuts to support the front panel? It's so long since I removed a front subframe I cant recall what's attached to what!
#4 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 30 October 2018 - 08:27 PM
Yes that's correct
#5 mk1leg
mk1leg
  • 9,343 posts
Posted 31 October 2018 - 07:58 PM
well When I bought My ERA turbo it need towing as it had not turned a wheel since 2004 but couldn't be towed or put on a flat bed so I needed a hoist.....so when I started the resto I removed the front Number plate and hay presto a towing Eye
#6 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 31 October 2018 - 08:42 PM
If you remove them, M10's fit perfectly.
#7 nicklouse
  • 18,696 posts
Posted 31 October 2018 - 09:47 PM
but the correct answer should have been 5/16ths
#8 Gillybobs
Gillybobs
  • 243 posts
Posted 31 October 2018 - 09:48 PM
I've added towing eyes to my car ! Fitted the ones from mini smiffy
https://www.ebay.co....redirect=mobile
#9 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 01 November 2018 - 03:07 AM
However the towing fittings are 3/8" (9.5mm) and have a much better fitment. The fitting of the 5/16" is due to the poor tolerances in the bodies. M10 fits perfectly and is commonly available in high tensile steel. Neither is wrong, however if you're a purist, get the imperial, ill fitting option.
#10 luismx123
luismx123
  • 525 posts
Posted 01 November 2018 - 11:16 AM
how would I mount this type of tow-eye? https://www.ebay.co....d-/170970002861
#11 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,725 posts
  • Name: Chris
  • Local Club: None
Posted 01 November 2018 - 11:25 AM
Front or rear?
#12 luismx123
luismx123
  • 525 posts
Posted 01 November 2018 - 02:58 PM
Front or rear?
uhhh....both? :D nah probably front but yea...
#13 minitravellerman
minitravellerman
  • 99 posts
  • Local Club: Minis In Northern Ireland
Posted 01 November 2018 - 03:02 PM
I have one of these type fitted to the rear of my MG ZR - basically it clamps to either side of the OEM tow hook. It's quite a substantial piece of equipment.
247182_10201194632370650_2014276794_n.jp
#14 minitravellerman
minitravellerman
  • 99 posts
Posted 01 November 2018 - 03:07 PM
What rear tow mounts have others used on their Minis? I am thinking of adding one to my Traveller but with the position of the number plate I'm at a loss of how best to do so.
One I am considering if I could get one or get a copy made is the SPQR type (item 19 on the attached SPQR flier)
#15 nicklouse
  • 18,696 posts
Posted 01 November 2018 - 03:12 PM
the problem you will have is you have your fuel tank to get in the way. almost worth fitting a tow bar.
