Hi all,
thank you very much for your replies!
@DeadSquare - thanks for the post, funny enough I am based in Greece so that would have been a great opportunity but as other noted it is not the right part number.
My engine will be a mildly turbo'ed fast road build used as a daily driver so I am not going purely "stock" but at the same time won't be boosting like crazy and squeezing every ounce out of those 1275cc's.
@ACDodd thanks for pointing that out, I was not aware that this was an economy version but after looking at minispares I confirm that the groove in the shoulder of the gear indicates it is the 28 tooth model.
-So this means that my gearbox has overall higher gearing than a standard Mini one?
I have already opted for a 3.1 diff and I will be using 10 inch wheels (the rationale being that the increased torque from the turbo would help with acceleration and at higher speeds the car would become more drivable since I will use it as a daily driver).
-If my gearbox is also geared higher am I possibly going a bit too far with all these combined?
-How different is this economy model to the standard?
Any opinions would be more than welcome.
Cheers,
Nik
Edited by nikollou, 06 November 2018 - 08:15 AM.
