Yes the compression ratio is likely too high.
Ok so you have the 28tooth input gear and a 30tooth primary. This gives an overdrive ratio of 0.93333:1. Your 3.105:1 FD effectively becomes 0.93333 X 3.105 = 2.898:1.
This is probably higher that what you were expecting. It also demonstrates thats it's important to know what exact parts are fitted to your engine in order to make a successful build.
Ac
Chipped Input Gear - Can I Still Use It?
nikollou
, Nov 05 2018 09:15 AM
15 replies to this topic
#16
Posted 07 November 2018 - 05:37 PM
