I came across a 12g295 in virgin condition a little while ago and set about having it overhauled by Kieth Calver.
Now the spec of my engine as i was lead to believe was a 1098 with +30 re-bore and a 997 cooper cam. I gave these specs to KC and he worked his magic to produce a great bigger valve version ready to fit bar a skim to get the right CR.
Now, it turns out that the engine in fact has only had a 20 thou bore and there is a small chance that the valves might touch the block as they are larger than the originals.
I have the 997 cooper cam with a measured lift of 0.256
A set of 1.3 rocker which for arguments sake and for the reason of tolerance (worst case) i will class as a true 1.3
This gives an exhaust valve lift of 0.333.
Now the head has been skimmed i have an exhaust valve to head face clearance of 0.350
Ignoring the gasket thickness (0.032) and the backlash in the rockers (0.015) is this enough tolerance for a safe build? 0.350 - 0.333 = 0.017
I am thinking that it should be enough of a gap once the gasket and rocker backlash are factored in. I am going to do a dry build minus the gasket to see but i wondered what people thought.
