Floor Tunnel Heat Shield
4 replies to this topic
#1 Sprok
Sprok
  • 135 posts
Posted 07 November 2018 - 09:32 AM
Hi guys
Im restoring an spi and have put in a complete new floor.
The new floor didnt come with the screws to fit the tunnel heat shield and to be honest thats where i found alot of corrision as water clearly traps between the shield and the floor where it is bolted on.
I want a better solution in order to reduce corrosion in the future. Anyone seen anything better?
Ive heard peope sticking dynamat under the tunnel but i thought that was accoustic matting?
I know i could lagg the exhaust but was looking for a shield solution ?
Edited by Sprok, 07 November 2018 - 09:32 AM.
#2 nicklouse
  • 18,748 posts
Posted 07 November 2018 - 09:48 AM
mount a metal standoff to the exhaust. no real need for it to be car mounted. and then there is the question is it really needed?
#3 harrythehat
harrythehat
  • 275 posts
Posted 07 November 2018 - 09:58 AM
Was wondering the same myself as just broke a corner off right on the screw mount whilst removing the subframe
it would really only get hot hot if sitting ticking over for ages
#4 Dutchdave's25
Dutchdave's25
  • 105 posts
Posted 07 November 2018 - 11:08 AM
i am using something like this:
https://www.heatshie...barrier-fi.html
i have bought it but not installed it yet, so i cant tell you if its a good idea ;)
#5 Sprok
Sprok
  • 135 posts
Posted 07 November 2018 - 11:25 AM
Brilliant suggestion about mounting the shied to the exhaust itself !!! Great thats a good solution.
I looked at heat tape but i think an air gap with a shield will prevent heat transfer better?
That will be plan B ;)
