How Is The Spare Wheel Clamp Fixed?
6 replies to this topic
#1 riczito
riczito
  • 54 posts
Posted 08 November 2018 - 06:41 AM
Hi all,
Fed up with the spare wheel banging around in the boot on bumpy roads, I bought a Mk1-style spare wheel clamp. It arrived yesterday, and the boss which fixes to the boot floor isn't pre-drilled. Am I to assume it was glued to the floor? Contact adhesive or Araldite might do the trick. Or should I drill and bolt it? Or some self-tapping screws?  Just curious to know what others have done.
Here's the two-piece clamp : http://www.minispare...ic/14A6511.aspx
cheers,
Ric
#2 GraemeC
GraemeC
  • 7,438 posts
Posted 08 November 2018 - 06:45 AM
Normally spot/plug welded
#3 riczito
riczito
  • 54 posts
Posted 08 November 2018 - 07:02 AM
Ah OK. I think I'll glue it. Welding isn't feasible for me. Thanks!
#4 Laska
Laska
  • 38 posts
Posted 10 September 2020 - 03:29 PM
So how did the adhesive option work out? I was thinking of doing the same. Did it work?
#5 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,037 posts
  • Name: Neil
Posted 10 September 2020 - 03:57 PM
To be honest if you are trying to bond it then why not nut and bolt it??
#6 Laska
Laska
  • 38 posts
Posted 10 September 2020 - 04:25 PM
Only becuse I don’t want to drill the floor and I do not have access to a welder.
#7 croc7
croc7
  • 810 posts
Posted 10 September 2020 - 06:51 PM
I marked the location with a felt tipped pen, took it to a body shop where they welded it to the boot floor for me.  Only consideration was to cover the tank with a fire proof blanket.  They liked the car, so "no charge".
