Engine Bushings
6 replies to this topic
#1 PauloPereira
PauloPereira
    Just On Tickover
  • 9 posts
Posted 08 November 2018 - 10:11 AM
Hello. I have a MPI and want to replace the bushings on my upper and lower engine steady bars, (getting a knocking noise when shifting). I know that the MPI has a different bushing than the earlier minis. Is the bottom ones the same as the MPI upper? And could I possibly use the older style bushings on the MPI? Is the diameter the same? thanks
#2 mini13
mini13
  • 3,811 posts
Posted 08 November 2018 - 10:21 AM
the MPI bushings are much better, thats why they changed them.
#3 PauloPereira
PauloPereira
    Just On Tickover
  • 9 posts
Posted 08 November 2018 - 10:22 AM
Are the bottom ones the same as top?
#4 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 08 November 2018 - 10:32 AM
Looking at the Moss Europe website, the part number is the same for all the bushes: upper and lower ... but it doesn't mention any model specific changes.
https://www.moss-eur...liser-mini.html
https://www.moss-eur...isers-mini.html
MiniSpares do list different bushes depending on year
http://www.minispare...ounts.aspx?1002
Edited by gazza82, 08 November 2018 - 10:34 AM.
#5 mini13
mini13
  • 3,811 posts
I belive so, I know that aftermarket bottom ones that go backwards to the subframe use a larger bolt, but the bushing can be drilled to suit.
Also minispares do an uprated version for the bush for performance use, which is what I use.
#6 nicklouse
  • 18,998 posts
Posted 08 November 2018 - 10:37 AM
I have the same bushes in all my stabilizers.
they are all basically the same. have the same fitted size. some are harder to fit in the stabilizers than others.
#7 PauloPereira
PauloPereira
    Just On Tickover
  • 9 posts
Posted 08 November 2018 - 10:49 AM
Great! Thanks for the help guys. Appreciate it.
