Oil Pressure Sensor Wiring
3 replies to this topic
#1 Trissy B
Trissy B
  • 381 posts
  • Local Club: Bognor Regis Motor Club
Posted 11 November 2018 - 08:09 PM
Hello everyone, apologies for probably asking a very simple question but I am rubbish at wiring!!
I've brought a oil temp gauge that I'm in the process of putting in. They gave me a decent wiring diagram that makes a bit of sense.
I have a mechanical oil pressure gauge at the moment and no oil pressure warning light. So i've taken the opportunity to wire a 20psi minispares one in.
I have a sender all plumbed in with T piece, a load of spare wire and a warning light.
I guess it needs wiring in series: some power to the bulb, then sender then earth.
Question is - do i need 10v from the voltage regulator or 12v from elsewhere?
[/url]2018-11-11_07-49-07 by Trissy B, on Flickr">http://<a href='http....kr/p/2a4v8NU'>44015537460_f83dadb7fb_k.jpg2018-11-11_07-49-07 by Trissy B, on Flickr
#2 GraemeC
GraemeC
  • 7,440 posts
Posted 11 November 2018 - 08:41 PM
It is likely to be a 12V bulb. You could run it with a 10V supply, it would just be slightly dimmer.
As standard, only gauges run at 10V. I don’t know if the regulator would be able to cope with the load from a bulb.
#3 nicklouse
  • 18,675 posts
Posted 11 November 2018 - 08:49 PM
just wire at 12Volt
#4 Trissy B
Trissy B
  • 381 posts
Posted 11 November 2018 - 09:17 PM
Good stuff thanks. The light will be right next to the tacho so will nick some power off that.
