Headlight Ballast Resistor
Posted 12 November 2018 - 09:01 PM
Does anyone know anywhere that sells headlight ballast resistors please. Cant find them anywhere ?!
Posted 12 November 2018 - 09:26 PM
Ballast resistor wire was fitted in place of the coil live wire to reduce operating voltage
Posted 12 November 2018 - 09:30 PM
Hi
why would you want to re fit it not needed not a legal requirement. if you really want one then put a wanted advert as there will be many out there that people have taken off.
Posted 12 November 2018 - 09:41 PM
Your headlights won't have ballast resistors as standard.
If it has a dip dim relay they will.
Available on ebay if you do want to keep one fitted.
Posted 12 November 2018 - 09:52 PM
If it has a dip dim relay they will.Your headlights won't have ballast resistors as standard.
Yes just a normal resistor, not a resistive cable(like the pink/white wire for coil+ on some minis)
Posted 13 November 2018 - 01:22 PM
I just took it off the car and its broken so i was thinking id have to put a new one back.
No idea what its for or what it does but i understand its something to do with headlights ??
Cant find one. Looked on ebay.
If i didnt fit it woukd lights work? Is there an alternative ?
Posted 13 November 2018 - 01:32 PM
https://www.autoelec...mbly-2476-p.asp
The dim-dip system is something often removed/defeated/bypassed when it starts to give trouble. There are threads on here with the details should you go that route.
Phil.
Posted 13 November 2018 - 02:42 PM
As above, just delete the dim-dip relay system if it's starting to have problems.
Posted 13 November 2018 - 05:34 PM
PERFECT thankyou. One on its way !!
Posted 22 November 2018 - 11:10 PM
Guys. First of all electrics are not my forte.
This thread may interest you: http://www.theminifo...trical-gremlin/
